Results 1 to 10 of 322
Thread: 1974 XS/TX650 rebuild
    Oct 2015
    th62's Tools
    A little premature, but I did a little detailing. Stainless fasteners don't look the best straight off the shelf, so I've started neatening them up a little. Allen heads have striations on the side of the heads and numbers stamped on the face of the heads, so I chucked a heap of them and turned them down a little before polishing. Hex heads were very rough, so they were ground down a little before polishing. I ground and polished the ends of any bolts that were seen as well as removing the excess thread..
    I've only done one side of the bike, tomorrow I'll tackle the other. Then the engine fasteners, a few little ones on the carbs. I haven't done the washers, can't figure out how to hold them without polishing the ends of my fingers.
    The footpeg holes to which I mount the mufflers are 12mm, heads of the fasteners on the inside looked like they'd scrape against the swingarm, so I turned up some brass shim tubes and pressed them into place so I could use 10mm fasteners, they just clear the swingarm.
    Once I've finished, I'll remove the clear coat and just leave the ally bare.
ID:	43730   Click image for larger version.
ID:	43731   Click image for larger version.
ID:	43732   Click image for larger version.
ID:	43733   Click image for larger version.
ID:	43735   Click image for larger version.
ID:	43736   Click image for larger version.
ID:	43737   Click image for larger version.
ID:	43738   Click image for larger version.
  2. The Following 3 Users Say Thank You to th62 For This Useful Post:
    asterix (Sep 15, 2022), greenie (Sep 15, 2022), tonyfoale (Sep 15, 2022)
