Results 1 to 8 of 8
Thread: 3-in-1 DIY Knife Sharpening System Jig
  1. #4
    Mazay's Avatar
    Jul 2019
    Mazay's Tools
    Quote Originally Posted by Karl_H View Post
    I am sure that tomato can't tell an 8 degree angle from a 9 degree angle.
    That's a great tomato joke. You made me laugh.
    Are you calculating/measuring angles for your edge, or just getting close enough to the existing angle?
    I am using protractor application on a smartphone. It turns out a very accurate measurement.
    At first, I planned to calculate the angle according to the size of the device, this would give an accuracy of about + - 1 degree, taking into account the different projections of the knife tip. Based on the calculations, just make a set of sticks that would allow you to quickly measure the distance from the base to the bottom of the hinge. But using the application turned out to be easier, with higher measurement accuracy.
  2. The Following 2 Users Say Thank You to Mazay For This Useful Post:
    emu roo (Dec 2, 2025), Karl_H (May 19, 2020)
