no holes needed in washer, it could be ribed at edges or pocket for it. some thick silycone gadgets use a sleve the right length instead of washer.so silycony gadgets used a thin steel/stainless/aluminum incert between the gasket to stiffen the enitre hasket up so it did not squish out or suck un. I think those are almost gone as many did not work as the silycone could still be over tightened and squish it off the center support sheet.thats when they started encapsulating the gaskets in the parts they were made to fit.a few nubs to hold them in place and a total soround of the part on each edge keeps the soft gasket in plase so it can do it's one job.seal!!! but you dont have that so you need the gasket to have a solid seat(washer at each bolt/screw/fastner location) I suppose for some applications it may not even need that where the load is spread over a large area like timing covers on engines,chevy,ford,mopar and more.and the best part is your gasket would be reusable .witch is great for performance guys. wow, this kinda makes me wish I wasent getting out of the perfromance end of things....keep up the great work!!!
what part of GA are you in?
