Results 1 to 5 of 5
Thread: 4 battery hold down
    4 battery hold down
    it seems our truck is morphing into an RV more and more each time we do anything to it.
    While most truck drivers want to cut as much weight as possible out of their trucks because after all the payload is what pays the bills.
    But Bob has always been more in the position to pick and choose what get hauled on his rig and what does not.
    A while back we mounted an auxiliary power unit on the truck to provide 120v AC/ keep the batteries charged and other things We have a roof top RV air-conditioner / heater, microwave TV, refrigerator laptop/ scanner-printer-fax machine plus other accessories so the generator runs quite often when the truck is parked and has to run to power the 120v equipment so to counter this a little we decided to add a 3000/6000 watt inverter but this would put a lot of strain on the existing batteries in the truck So I added a battery box to hold 4 additional duel purpose batteries but there was no hold down so yesterday I made a hold down so we could install the batteries
    I started out with an old bed frame for the materials to make the hold down out of
    This is what I came up with then painted it with KBS stainless steel top coat spray paint
    the rear lock downs open
    and closed
    having the right tools to makeup cables is a must for me
    then protecting them from arcing/ wear and sealing out moisture with shrink tubing insures long life
    All he has to do now is buy 3 more new batteries and he will be nearly set
  2. The Following 10 Users Say Thank You to Frank S For This Useful Post:
    baja (May 19, 2020), dubbby (May 24, 2020), emu roo (Oct 22, 2025), hansgoudzwaard (May 22, 2020), Jon (May 21, 2020), KustomsbyKent (May 24, 2020), PJs (Oct 26, 2025), Rikk (May 21, 2020), Seedtick (May 18, 2020), Toolmaker51 (May 20, 2020)
    Thanks Frank S! We've added your Battery Hold Down to our Automotive category,
    Lake Tahoe
    IntheGroove's Tools
    I've always been a big fan of using bed frame angle iron for many jobs. And it's always free...
  6. The Following User Says Thank You to IntheGroove For This Useful Post:
    jdurand's Tools
    I've found the hydraulic crimpers make a nice little press if you take the dies out. Mine has a C shape, one die attached to the top of the C and the other to the piston with magnets.
  8. The Following User Says Thank You to jdurand For This Useful Post:
    I have one of the C type as well but it is way larger than the little 16 ton unit I used
  10. The Following 2 Users Say Thank You to Frank S For This Useful Post:
    emu roo (Oct 22, 2025), woodcutter (May 25, 2020)
