After making a scissor knurling tool, I become intersted in making a straight knurling tool since it:
> is greath when you need transmit torque between a steel shaft and a plastic wheel.;
> it can bring me more choices when making stuff;
> I can "save" a interference mount part infortunatelly made too loose.
I took a 1/2" square and milled the wheel slot
Turned the 1/4" pin from a 1045 bar. Here you can see there a section slighty bigger for interference fit
Pin was heated red hot and quenched in water.
After welding the side tab and cross drilling the 1/4" hole, I pressed the pin
Test run. I've made a fine (0,8mm) and a coarse (1,25mm) wheel.
My knurl set
now waiting rain give a break for paint the tool...
