Results 1 to 4 of 4
Thread: Cutting a 127mm diameter chamfer with a 12mm radius toolpath.
    Supporting Member Mook's Avatar
    Sep 2023
    UK
    Mook's Tools
    This trick uses the inside of the 6" face mill inserts to cut a true large 45 degree chamfer around the perimeter of a 5" bar end. This is a big timesaver on a cnc saving a toolchange and the toolpath using a small chamfering cutter of around 400mm to one less than 40mm.
  2. The Following 8 Users Say Thank You to Mook For This Useful Post:
    albertq (May 15, 2024), emu roo (Jun 5, 2024), Inflight (Jun 9, 2024), Jon (May 31, 2024), mwmkravchenko (May 19, 2024), nova_robotics (May 15, 2024), Ralphxyz (May 15, 2024), Sleykin (Jun 5, 2024)
