DIY air separator
This is a homemade air separator for my plasma cutter and sandblast cabinet. I made it portable so that I could use it at either the plasma cutter or the sandblast cabinet. Also allows the air more time to cool down from the compressor before it gets to the separator. It seems to work pretty good, check it out!
https://youtu.be/d4LNaBAM2yk
Thanks Sgbarker! We've added your Water Separator to our Air Compressors category,
as well as to your builder page: Sgbarker's Homemade Tools. Your receipt:
<div id="blocks">
<div class="block b1 pngfix">
<div class="bimg">
<div>
<a href="https://www.homemadetools.net/homemade-water-separator-2">
<img src="/uploads/228820/homemade-water-separator-2.jpeg"/>
</a>
</div>
</div>
<div class="title">
<a href="https://www.homemadetools.net/homemade-water-separator-2">Water Separator</a>
<span> by <a href="https://www.homemadetools.net/builder/Sgbarker">Sgbarker</a></span>
</div>
<div class="tags">tags:
<a href='https://www.homemadetools.net/tag/air-compressor'>air compressor</a> </div>
</div>
</div>
</div>
Nice build, I like the portability.
Very nice. And copper is not only safe for compressed air, it should conduct heat away from air better than black or galvanized pipe.
I'd add two things. A small separator at inlet; plexi bowl would make accumulation visible. Using petcocks or needle valve drains instead rather than ball valves, being easier to 'crack' open.
But it works! Not only Portable but Attached; big step saver.
Thanks! That’s awesome! I really enjoy sharing! And everyone is very supportive!
Just a thought before you paint the copper. I think it would probably work better with no paint on it as copper is a good conductor of heat and would probably help it do its job better without paint at it. I also like the idea of petcocks for drainage. Just my 2 cents. Nice build.
