Results 1 to 4 of 4
Thread: Doc tries some metal work...
    Doc
    Doc is offline
    Supporting Member Doc's Avatar
    May 2013
    Doc's Tools
    Lightbulb Doc tries some metal work...
    Hi everybody.
    As I've mentioned before, I'm a wooden toy maker/wood worker and pretend wood turner. Since recently aquiring a small workshop area (3m by 3m shed) just for metal work, I decided to make a few tool rests for my wood lathe.
    The steel was cut to size (the bent piece was already that shape) and then cleaned - wire brush/grinder and arc welded (?stick welded??) to a bolt that fits my lathe banjo.
    The top two piccies are of the same rest - about 200mm on the longest side. The bottom left is a small T rest of about 100mm and the long doodad rest is about 350mm long - allows me to turn a wand without moving my banjo - yeah, I'm lazy
    When I welded each piece I also ground back the welds to check to make sure that I had plenty of melted steel (forgot the correct terminology) - welder friend of mine suggested it. He said if I do that often enough I'll turn into a decent welder rather than the best metal grinder
    Anyhoo, enjoyed myself playing with a welder. A bit addictive, non?
    Regards
    Doc
  2. The Following 2 Users Say Thank You to Doc For This Useful Post:
    Christophe Mineau (Feb 10, 2015), kbalch (Feb 10, 2015)
    Jul 2014
    France, Brittany !
    Christophe Mineau's Tools
    Well done Doc, I have to do some also, but makes me thinking that I have already done one, a piece of art of brazing job
    I have to show it !
    The shape I would like to do is a rounded shape to get inside bowls.
    But for the moment, I have some difficulties to find some good diameter round stock (without purchasing)
    Thanks Doc !
    Christophe
    Cheers !
    Christophe
    Facebook : La Belle Note
  4. The Following User Says Thank You to Christophe Mineau For This Useful Post:
    Doc (Feb 10, 2015)
    kbalch's Avatar
    Jun 2012
    Clermont, FL
    Thanks Doc! I've added your Lathe Tool Rest to our Metalworking and Wood Lathes categories, as well as to your builder page: Doc's Homemade Tools. Your receipt:
  6. The Following User Says Thank You to kbalch For This Useful Post:
    Doc (Feb 10, 2015)
    Jul 2014
    San DIEGO, California
    Captainleeward's Tools
    Well done Doc...:O)
  8. The Following User Says Thank You to Captainleeward For This Useful Post:
    Doc (Feb 11, 2015)
