Results 1 to 8 of 8
Thread: drill jug for drilling holes in washers
  1. #3
    Just today I explained to a younger friend,(Chef by Trade who I am teaching a bit about machines),about how washers are always a bit larger than the bolt or stud they are intended for and how by mixing Imperial and metric you can usually get a closer fit if needed.
    The investment in those risers is certainly paying off.
    Also different grades of washers have different Id's and OD's, washers also have a top and a bottom when installing. On softer lower grade s this will be noted by the rounded edges on 1 side and sharp edges on the other, for hardened or machined washers the top is denoted by a slightly larger bevel on the ID, these rounded or beveled sides should always be installed next to the bolt heads, this is to lesson the possibility of creating a pinch moment with the fillet radius of the bolt head which could result in a stress fracture of the bolt. the hole Id of washers are larger than the bolt diameters for much the same reason.
    bob47907 (Mar 9, 2022), JTC (Mar 13, 2022), piper184 (Mar 10, 2022), Sleykin (Jun 8, 2022)
