Results 1 to 10 of 27
Thread: Easy forge/Foundry
    Supporting Member MountainMan's Avatar
    Jul 2018
    Conway,SC
    MountainMan's Tools
    Easy forge/Foundry
    I went out to my scrap pile to find material to put together a forge for knife making but also wated to be able to use it as a foundry for melting down aluminum chips from the lathe and casting them into new parts. So I found a old brake drum and a old turkey fryer base that fit together perfectly. I ran to the hardware store and got 1.5" galvanized flange and bolted it to the brake drum. I used a 4" galvanined nipple with a T for my air intake and the bottom side of it is the ash dump. It works great as a coal forge and melts aluminum easily. Just thought I would share to help anybody else out if they where considering building one.
    Dave
    "I have not failed...I've just found 10,000 ways that wont work"
    Thomas Edison
  2. The Following 25 Users Say Thank You to MountainMan For This Useful Post:
    baja (Jul 27, 2018), ben yeakey (Nov 23, 2018), billster (Jul 27, 2018), bukwessul (Jul 27, 2018), Captn Roy (Jul 29, 2018), casca92 (Jul 27, 2018), clydeman (Sep 3, 2020), cohay1 (Apr 18, 2020), DIMDIM (Aug 17, 2018), greyhoundollie (Nov 24, 2018), gunsgt1863 (Jul 28, 2018), high-side (Sep 4, 2020), HobieDave (Mar 19, 2020), JD62 (Jul 27, 2018), jdaley (Jul 28, 2018), Jon (Jul 28, 2018), JRock (Aug 6, 2018), old_toolmaker (Jul 31, 2018), PJs (Jul 28, 2018), Priemsy (Nov 23, 2018), Ralphxyz (Nov 10, 2023), redearthbonsai (Jul 27, 2018), rossbotics (Jul 31, 2018), sdiverjack (Aug 6, 2018), Seedtick (Jul 30, 2018)
