Your vice idea is a good one if the vice jaws stick up enough to grip the nuts safely. The easiest way I've found to spread U bolts up to an inch in diameter is to use a couple lengths of pipe over the bolts. Obviously the bigger the bolt the bigger and longer the pipes need to be.
