Results 1 to 10 of 30
Thread: Home Made angle plate for disk sander
  1. #5
    Supporting Member 737mechanic's Avatar
    Nov 2018
    Dallas
    737mechanic's Tools
    This is a genuine question not a criticism.
    Why are disc sanders popular? I have always failed to see any benefit over a belt sander. The surface speed varies over the face whereas it is constant with a belt.
    I have a combined belt and disc sander but I have removed the disc because I could not find any application which the belt did not do better.
    What am I missing?
    I agree that a belt sander is nicer, to be honest, the variable sfpm isn't a concern but I would rather have a belt sander but all I have is the disk sander, I also have a bench grinder but the important thing here is even with a belt sander as long as you have a table with a slot which most belt sanders do then you could make an angle plate for it the same way.
  2. The Following User Says Thank You to 737mechanic For This Useful Post:
    tonyfoale (Jul 4, 2019)
