Results 1 to 10 of 30
Thread: Home Made angle plate for disk sander
  1. #19
    Feb 2018
    You cannot appreciate a disc until you have worked with a big heavy machine, the disc alone is about 100 lbs each side. You can push much harder on a disk because a belt would stall due to the drive. Belts certainly have the advantage of changing grits in a few seconds, that is why I have multiple disc sanders. Most shops only change the bigger discs once or twice a year, they last many hours with skilled use.
  2. The Following User Says Thank You to Tooler2 For This Useful Post:
    Jon (Jul 4, 2019)
