Results 1 to 10 of 32
Thread: Homemade tools made with Harbor Freight tools
  1. #24
    [QUOTE=Iconoscope;79244] There is no shear pin and that is a potential disaster waiting to happen. I would like to devise an adjustable means to disengage the half nut when the carriage approaches the chuck or face plate.[QUOTE]
    You'll need to complete a short list of details:
    1] Wire will be unsatisfactory unless you can calculate torque [by diameter and grade of material turned x deepest cut acceptable x appropriate feed rate] of the lead screw at full load, in to select section diameter to withstand that shear force.
    2] Wire requires close fit to drilled AND reamed hole, or you'll endure backlash issues. A taper dowel would be more conventional. A small OD rollpin would be decent alternative. Rollpins are hardened spring steel; shearing is certain to raise a burr between shaft and coupling. A simple fixture bored to lead screw OD, clamped by a pair of machine screws, and a predrilled guide hole is one solution. Assembly could be removed to mill or drill press.
    3] Typically and intentionally that will not be physical centerline, when pin breaks, correct 180 reorientation will be unmistakable. Use a ball endmill for starting pocket. Cutter geometry resists deflection better than web of center drill off-axis from apex of round stock.
    SOME lathes use a face clutch. In general, that's radial teeth of gear profile or 45 degrees rigidly fixed to one side. The other side is pushed into engagement by coil spring(s) backed by a simple adjustment, a threaded nut. Increase the pressure until the bare minimum of positive engagement is attained.
    Some larger lathes arrange a projection through bottom of carriage that tips off feed of X axis. Can't think of many examples for threading. Adding instantaneous action seems problematic to equip carriage thus.
    Then sell it back to HFT engineering at a serious $$ premium.
    As usual, I invite email/ posts with questions on anything unclear or neglected.
    Last edited by Toolmaker51; Nov 16, 2016 at 07:05 PM. Reason: embolden portions of qoute, expand details
  2. The Following User Says Thank You to Toolmaker51 For This Useful Post:
    Iconoscope (Nov 17, 2016)
