Results 1 to 8 of 8
Thread: Milling vice inserts for round material.
    Supporting Member Mook's Avatar
    Sep 2023
    UK
    Mook's Tools
    Holding round parts in a milling vice can be difficult if the part is larger than the available vee blocks. This simple pair of low profile identical jaws can hold from over 160mm diameter down to below 30mm diameter with reducing pins. Smaller diameters can be held using larger rollers.
    If the part sits below the jaws the use of an indicator on the part perimeter is not possible. As the jaws are identical & exactly 100 mm wide an edgefinder is easily used to find the X dimension @ 50mm from one edge. The Y dimension is mid point between the vice jaws. These two dimensions will give the centre of the disc without having to edgefind on curved surfaces.
  2. The Following 24 Users Say Thank You to Mook For This Useful Post:
    albertq (Mar 17, 2024), brianhw (Oct 30, 2023), Canyonman44 (Oct 30, 2023), Carnel (Oct 31, 2023), cjfearn (Oct 30, 2023), cognitdiss (Oct 31, 2023), Harvey Melvin Richards (Oct 30, 2023), johncg (Oct 30, 2023), Jon (Oct 29, 2023), metric_taper (Oct 30, 2023), mr mikey (Oct 30, 2023), nova_robotics (Oct 30, 2023), phred (Oct 30, 2023), piper184 (Oct 31, 2023), Ralphxyz (Oct 30, 2023), rlm98253 (Oct 30, 2023), thadrodgers (Oct 30, 2023), that_other_guy (Aug 21, 2024), thehomeengineer (Nov 1, 2023), trevor_60_r (Nov 2, 2023), Tule (Oct 30, 2023), uv8452 (Oct 30, 2023), whitebear (Oct 30, 2023), WmRMeyers (Oct 29, 2023)
    Thanks Mook! We've added your Mill Vise Inserts to our Vises category,
    as well as to your builder page: Mook's Homemade Tools. Your receipt:
    Supporting Member mr mikey's Avatar
    May 2022
    Michigan
    mr mikey's Tools
    Very nice setup. Thanks. Mike.
    Supporting Member Canyonman44's Avatar
    Mar 2014
    Blueprints?
    Oct 2019
    Sell them?
    Sep 2023
    UK
    Mook's Tools
    Thanks for the comments.
    Here is a link to the drawings in PDF format. - https://drive.google.com/file/d/1SUj...ew?usp=sharing
    My original challenge was to have rotating rollers with a self aligning flat on them to help prevent marking of the component. It became a bit too complicated and with more parts progressive errors can creep in. So I decided on this simple design to prove the concept. However after a rethink, I have a simpler solution to incorporate rotating flatted rollers.
  8. The Following 2 Users Say Thank You to Mook For This Useful Post:
    mr mikey (Oct 31, 2023), nova_robotics (Nov 4, 2023)
  9. #7
    Congratulations Mook - your Mill Vise Inserts are the Homemade Tool of the Week!
    Nice solution, and thank you for adding the drawings, and we look forward to your next iteration for incorporating flatted rollers.
    Universal Handle by My MiniCrafts
    Graduating Tool by PaulsGarageProjects
    Knife Bevel Jig by Mazay
    Tapered Gauge Pins by Workshopfriend
    Round Stock Support by orioncons36
    Tool Grinder Bed Stop by thehomeengineer
    Mook - you'll be receiving a $100 prize, in your choice of Amazon, PayPal, or bitcoin. Please PM me your current email address and prize choice and I'll get it sent over right away.
    This is your 2nd Homemade Tool of the Week. Here are both of your Homemade Tool of the Week winning tools. Congrats again
  10. #8
    Sep 2023
    UK
    Mook's Tools
    Thanks for the award.
    As promised here is a sneek peek at the self aligning rotating roller design.
    https://drive.google.com/file/d/1B_t...ew?usp=sharing
    https://drive.google.com/file/d/19ik...ew?usp=sharing
    Milling vice inserts for round material.-img_20231103_171257_edit_81222751074063.jpg
    Download plans for vises.
  11. The Following User Says Thank You to Mook For This Useful Post:
