Results 1 to 6 of 6
Thread: Miniature powered turntable
    I finally got around to building a miniature turntable which I intend to use for a number of applications (see below). This project was prompted by my discovery of this motor-gearbox combination...
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    which consists of a 1" diameter DC motor geared down via a tiny gear box to 2 rpm. The motor draws about 25 ma and, given the gear reduction, has lots and lots of torque. Being 12 VDC, I can run it indoors on a wall wart or outdoors on a 12 volt SLA.
    I built a small table to support the motor and a circular turntable with a fitting to attach it to the 6 mm gearbox output shaft...
    Assembled the unit looks like this...
    Now, how will it be used?
    360 PHOTOGRAPHY...
    Generally, I prefer stills to videos for documenting things I make. However, there are times when a full 360 rotation of the object will provide a better visualization and that implies use of a turntable.
    Here's a good example of that...
    ENGINE SHOW ATTENTION GRABBER...
    Some of my engines are quite tiny so gather little attention even if running. A larger engine twirling about is bound to attract.
    PAINTING SMALL OBJECTS...
    I preserve the polished finish on small metal objects I've made (such as my homemade chess set) by spray painting with Rustoleum Crystal Clear Enamel. It's a much better and longer term solution than Renaissance Wax, especially for items that will be handled. While this sort of painting can be done with a manually rotated turntable, a small motor driven one makes it a lot easier. Since the work is usually done outside, the ability to power this table with a battery is a plus.
    ROTATING CAKE DISPLAYS...
    My wife makes OTT birthday cakes for our grandchildren. Many of the videos she watches for inspiration feature rotating elements as part of the design. I wanted to simultaneously build her something she could use immediately as well as explore for myself the adaptability of these small geared-down motors for future cake designs.
  2. The Following 11 Users Say Thank You to mklotz For This Useful Post:
    baja (Mar 4, 2020), bobs409 (Mar 3, 2020), DIYer (Mar 3, 2020), emu roo (Apr 16, 2025), Guy Marsden (Apr 28, 2022), Jon (Mar 3, 2020), oldpastit (Mar 4, 2020), Paul Jones (Mar 3, 2020), rlm98253 (Sep 7, 2023), Seedtick (Mar 3, 2020), Tonyg (Mar 4, 2020)
