Quote Originally Posted by rossbotics View Post
You're right Frank, thought of that but you know how it is when you get your mind set on something, just wanted to use socket heads cause the rest of the hardware is, but could have changed them all to buttons.
Doug
Still a good trick using the 1/4" allen to drive it. Seems I tried this once and ran into a root diameter issue leaving a small void...but then again I once got chewed out for using a 1/4-28 instead of a 1/4-20 because I thought the engagement was critical to what I was doing and the difference in the cost of a box of them was <$1 at the time. Who knew it mattered @¿@, but then again I think Button heads are classy.
Thanks Doug!
