Results 1 to 10 of 22
Thread: More on my lathe conversion
    A bit over a year ago I posted about my lathe conversion to electronic control. Not full CNC because I did not want that but way more than normal ELS conversions. Here is a link to that post
    Ball screw and electronic lathe conversion
    It has worked great since then until it didn't a few weeks back. I traced the problem to a dry joint on my hand wired control board. It looked perfect, even under a microscope, which is about the only way to inspect it. A continuity meter can only tell you if it is working or not at the time of measurement but it may not be tomorrow. Often just putting a probe on a joint can be enough physical effort to change its state. It seems like the modern solder is to blame, it does not tin out like the old leaded stuff. I think that what happened with mine was brought on by the weather. It was very damp over the winter, which would have allowed humidity into anything that was not perfect and caused some corrosion then the hot weather dried it all out. As a result I lost confidence in that board, how many more connections were waiting to cause a problem?. A PCB comes ready tinned on all the connection points and most component leads are tinned or tin easily. Soldering is a piece of cake, with minimal worries about dry joints. So the potential for similar problems is greatly reduced.
ID:	43266 Click image for larger version.
ID:	43267 Click image for larger version.
ID:	43268 Click for full size
    These pix show the original hand wired control board, not tidy but it worked for a year.
    So I sat down and designed a PCB to replace the hand wired board. I have made PCBs in the past on a milling machine but there were a few other people who would like a PCB to help copying my controller, so I decided to design one to get made professionally by one of the myriad of companies offering that service. I used some design software called Diptrace to help design the board. I had not drawn any schematics for the original, I tend to work off the top of my head mostly, so I went directly into manually placing components and then tracing through with the wiring. Here are the front and rear design layouts. Which become the only wiring diagrams that I have.
ID:	43269 Click image for larger version.
    Once that was done I converted it to a 3D image for a final check
ID:	43271 Click image for larger version.
    DipTrace then exported a bunch of "Gerber" files that the PCB companies use and I sent them off to such a company. Four days later I had these, The shipping was 8 times the price of 10 boards.
ID:	43273 Click image for larger version.
    Which were a pretty good imitation of the 3D model
    Populating the board with components was very fast and the final board looked like this with the original for comparison.
Name:	PCB with stuff.jpg
ID:	43275 Click image for larger version.
ID:	43277 Click image for larger version.
    It worked first time but it works no better than the original so what have I gained? Improved reliability and a warm fuzzy feeling whenever I open the cabinet door.
    Here is a link to the inevitable videos https://www.youtube.com/playlist?lis...JVwwFANxyTc2Kj and another pic.
  2. The Following 21 Users Say Thank You to tonyfoale For This Useful Post:
    asterix (Jul 25, 2022), bruce.desertrat (Jul 23, 2022), Christophe Mineau (Jul 23, 2022), darkoford (Jul 22, 2022), Duke_of_URL (Jul 23, 2025), emu roo (Sep 14, 2024), freddo4 (Jul 21, 2022), Home-PC (Jul 21, 2022), Inner (Jul 21, 2022), johncg (Jul 22, 2022), Jon (Jul 20, 2022), metric_taper (Jul 21, 2022), mwmkravchenko (Jul 21, 2022), nova_robotics (Jul 20, 2022), olderdan (Jul 23, 2022), Paul Jones (Oct 4, 2022), rebuilder1954 (Jul 22, 2022), rlm98253 (Jul 21, 2022), Saltfever (Jul 21, 2022), Tonyg (Jul 22, 2022), Tule (Jul 22, 2022)
