Results 1 to 4 of 4
Thread: Power feed for my mill.
    Feb 2015
    blackangus's Tools
    I built this power feed for my mill a while ago and thought I would post it. The motor was purchased at Princess Auto in their bargain bin so I don't have much info on it. The speed and direction controller I got off of ebay and the power supply is a garage sall item. When I first built it I tried it out and then left it sit, it was to much trouble to unhook it when manually doing some work. I found a dog clutch article by John Krueger on-line and recently made one following his plans and changing what I had to to make it work on my Craftex mill. Now I use the power feed for most things and the amazing part is how much better finish you get with a power feed especially when fly cutting. The speed range is very good, it will go slow enough to move only .25 of an inch in 2 minutes and will move 5-6" a minute on faster setting. The clutch is very easy to use so if I want to move very fast I disconnect the feed and do it manually. I will attach some photos and the PDF file of John's clutch. The pdj is to large to upload but this is the link to it. littlemachineshop.com/projects/Drawings/ClutchConnnector.pdf
    Attached Thumbnails Attached Thumbnails Power feed for my mill.-img_0391-800x600-.jpg   Power feed for my mill.-img_0390-800x600-.jpg
    Attached Images Attached Images
  2. The Following 2 Users Say Thank You to blackangus For This Useful Post:
    kbalch (Mar 25, 2015), Paul Jones (Mar 27, 2015)
    kbalch's Avatar
    Jun 2012
    Clermont, FL
    Thanks blackangus! I've added your Mill Power Feed to our Electrical category, as well as to your builder page: blackangus' Homemade Tools. Your receipt:
    Nice build, blackangus! As you noted, I like the speed range of your power feed.
    Supporting Member Gary A. Wills's Avatar
    May 2015
    Nice I'm going to put a power feed on my mill too. I've deen looking at the ones people build . I like the idea of a clutch will look into that. I want to put one on the head too , my mill has the round column , think I'm going to try and make a locating bar to zero it out up and down.
