Results 1 to 10 of 15
Thread: Precision Angle plate & V-block
  1. #9
    I certainly don't remember making such a calculation.
    If we want to determine the maximum size of cylinder the block can accommodate* we have to first establish the measuring configuration. Just spitballing, I would think something like...
    The chord between the two points of tangency of the cylinder with the V should be at least X distance below the line defining the width of the V opening. X might be defined as a percentage of the depth of the V measured perpendicular from the opening to the vertex.
    Of course, the angle of the V would need to be specified. Most are 90 degrees but 60 degree exist.
    Seems like we're not the only ones confused by this issue...
    https://www.practicalmachinist.com/v...y-mean-297809/
    * A tacit assumption here being that the cylinder may not be supported on the ends of the V but rather must be enclosed within the V.
  2. The Following 2 Users Say Thank You to mklotz For This Useful Post:
    emu roo (May 25, 2026), Toolmaker51 (Jun 12, 2020)
