Results 1 to 10 of 21
Thread: rotary table driven by stepper motor controlled by 2 Arduino's
  1. #7
    Marion, Iowa
    metric_taper's Tools
    Quote Originally Posted by thehomeengineer View Post
    Encoder Arduino code using Arduino Nano
    #include <SPI.h>
    #include <Adafruit_GFX.h>
    #include <Adafruit_SSD1306.h>
    #include <Wire.h>
    #define SCREEN_WIDTH 128 // OLED display width, in pixels
    #define SCREEN_HEIGHT 32 // OLED display height, in pixels
    // Declaration for an SSD1306 display connected to I2C (SDA, SCL pins)
    #define OLED_RESET 4 // Reset pin # (or -1 if sharing Arduino reset pin)
    Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
    const byte interrupt = 2;
    const byte interruptB = 3;
    const int encoder1PinA = 2; // encoder channel A,B (interupt pins)
    const int encoder1PinB = 3;
    float Pos1deg = 0;
    volatile float encoder1Pos = 0; //ticks of encoder will change, initial number is zero
    void setup()
    Wire.setClock(400000);
    // Serial.begin(9600);
    if (!display.begin(SSD1306_SWITCHCAPVCC, 0x3C)) { // Address 0x3C for 128x32
    //Serial.println(F("SSD1306 allocation failed"));
    for (;; // Don't proceed, loop forever
    attachInterrupt(0, runEncoder1, RISING ); // encoder pin on interrupt 0 >>(pin 2 on arduino)
    void loop()
    float Pos1;
    uint8_t oldSREG = SREG;
    cli();
    Pos1 = encoder1Pos;
    SREG = oldSREG;
    static int oldPos1;
    if (Pos1 != oldPos1) {
    oldPos1 = Pos1;
    I thought there would be an ISR routine for the attachInterrupt. Am I missing something in how arduino code works?
  2. The Following 3 Users Say Thank You to metric_taper For This Useful Post:
    emu roo (Sep 25, 2025), Paul Jones (Jan 15, 2020), thehomeengineer (Jan 15, 2020)
