Results 1 to 10 of 12
Thread: Self Contained Snowblower for Bobcat 310
    Lake Tahoe
    IntheGroove's Tools
    I built a snowblower for my Bobcat skid steer. I started with a couple of old Ariens snow blowers that I chopped up and welded back together to make a 54 inch unit. After trying different engines I settled on a Predator 670cc v twin rated at 22hp. I removed three of the six blades from the impeller, replaced the steel drive shaft with a Monel 400 prop shaft from an inboard boat. I made the shaft longer to add another bearing. Shaft is driven by a size 60 o-ring chain, no clutch. The chute has been lengthened and the chute guide was replaced with a tapered unit to throw the snow farther. The chute rotation is handled by a 12 volt seat motor and the chute guide is moved by a hydraulic ram connected to modified trim tab pump. Controls for the engine and chute are in the cab. This thing works quite well...
ID:	38140 Click image for larger version.
ID:	38141 Click image for larger version.
ID:	38143 Click image for larger version.
ID:	38145 Click image for larger version.
  2. The Following 6 Users Say Thank You to IntheGroove For This Useful Post:
    baja (Jan 28, 2021), Captn Roy (Feb 8, 2021), Crusty (Jan 27, 2021), ibdennyak (Jan 27, 2021), Jon (Jan 27, 2021), KustomsbyKent (Jan 27, 2021)
