Results 1 to 10 of 10
Thread: side kit for my 5x9 trailer
  1. #2
    Checking fit of the 2 side pieces for the rear section
    Next it was time to cut down the center section which has sliding door which was probably used as a grain dispenser
    sliced apart with the victor
    Checking for fit
    Now it is time to create some kind of latch for the tailgate that can be used even without the side kit.
    I decided to use a horizontal sliding cane bolt style latch However at the same time I wanted to make it so that the rear sections of the side kit would be secured as well also the latches should be designed so that if the tailgate was closed even if someone forgot to latch it it would not come open
    I started out with sleeve receptacles which would be embedded inside the tailgate I welded a washer on a piece of 3/4 Sch 80 pipe then torched it square to fit inside the tailgate top tube
    Something you wont often see is gloves on my hands To be fair I didn't bother cooling the assembly before inserting it in the tube and I am holding everything in place to tack the outside washer the gloves are deerskin size xxlg driver's gloves
    here you can see how the latch bar can protrude into the socket area for the end gate pieces
    This is the mating hole in the Stanton
    one latch in the closed position
    the handle must be lifted above straight out before is can be slid open
    in this position the tailgate is still latched
    it must be slid all the way before the tailgate will open
    continued next post
  2. The Following 3 Users Say Thank You to Frank S For This Useful Post:
    KustomsbyKent (Feb 16, 2018), Scotsman Hosie (Apr 1, 2019), Toolmaker51 (Feb 17, 2018)
