Hi Neil,
I totally agree, as with a lot of the things I have made over the years, I think it has many more applications than I envisaged such as you suggest. The idea is that it can be clamped on a welding bench using the 16 mm holes. I have designed it so it is able to be dismantled and packed away when not required. That being said, it is likely to be a permanent feature on the bench because the reach is quite long while folding away to the side neatly
Poppa Bird
