Results 1 to 10 of 412
    hard to believe I haven't posted to this page in a month.
    But can't say that I have done a whole lot to the building I spent some time getting my old Cab over Freightliner running then removed the pair of 150 gal. fuel tanks and mounted a small 70 gallon square tank on the frame behind the cab. Since the old truck is only ever going to be used as a yard donkey there is no need for the massive tanks plus with them hanging off the sides of the frame they were a little too close to the ground for my liking That and I didn't want to get them damaged since they are in good shape.
    After completing the roof I wanted to get my machine shop van moved into position before adding the lean to roof extension This meant that I needed to mine a lot of select clay fill to pad up a hard area for the trailer to rest on. and to prevent getting stuck trying to move it meaning the gin pole and the fork carriage had to come off and the bucket be installed so I could transport materials from the pit I am mining them from about 100 yards down hill from the shop. Before it is all said and done I will need to move between 400 and 600 cubic yards of material this will take a while as the old backhoe is really in need of some majorly expensive work if I wanted to have full power available. But one step at a time either spend tons of cash on it that is needed on the building or nurse it along at reduced power and get the job done
    I can carry about a yard and a half full bucket but can only climb the hill in low range at a creep or a yard at a time still in low range but twice as fast So far on my click counter I have climbed that hill 95 times 50 times before I could locate the trailer
    Hooked up ready to roll
    First attempt proved not enough pad build up
    After another 10 loads
    The trailer is in place within about 6 inches from where I wanted it ,close enough
    After another several trips up the hill I still don't have the pad completely ready for the parts trailer because after I get it in place I am planning on removing the axles and dropping it close to the ground
    the parts trailer is behind the freightliner
    Digging the trench for the electrical conduit
    By the time I have all of the fill in the shop the conduit will be almost 3 feet below the surface of the eventual slab
    Conduit connected to the homemade 6x8x4 J box
    KustomsbyKent (Mar 30, 2020)
