Results 1 to 10 of 39
Thread: Tool Post Grinder
    Dec 2013
    Florida
    rossbotics's Tools
    Tool Post Grinder
    I built this little grinder mainly for truing the jaws on my lathe and lathe centers, Maybe some light O.D. & I.D. grinding too.
    The grinder has two interchangeable spindles, One for I.D. work which holds mounted stones with 1/4" shanks, The O.D. spindle supports up to a 4" O.D. tool post grinding wheel up to 1/2" wide.
    The spindle is supported by two 5202 Double row shielded angular contact bearings rated at 10,000 RPM's. I machined 4 aluminum pulleys to accommodate the proper rpm's for I.D. & O.D. grinding. The I.D. spindle runs at 10,000 rpm while the O.D. spindle runs at 6,000. Changing spindles takes about 3 minutes.
    The motor is a Dayton 1/2 HP 10,000 rpm, That I got off e-bay, The bearings were ordered from Mc Master-Carr, The flat belt came from vbeltsupply.com, The hardware came from local suppliers.
    The grinder runs very smooth and relatively quiet, It did an excellent job on my lathe jaws, After they were ground I had a .0007" run out, Not to bad for a 3 jaw chuck.
    This grinder will fit lathes with a 10" swing and up with the correct spacer
    Below are some photos and a couple links to you tube showing the grinder in use.
    As always thanks for looking and happy machining
    Doug
    Click this link to purchase a set of these plans http://www.homemadetools.net/forum/t...er-plans-46306
    All the parts ready for assembly
    External spindle installed
    Internal spindle installed
    Internal Grinding
    External Grinding
    Comments are always welcome
    Doug
  2. The Following 19 Users Say Thank You to rossbotics For This Useful Post:
    aphilipmarcou (Jul 4, 2018), Christophe Mineau (Jan 18, 2016), CookieCrunch (Oct 26, 2018), derek160 (May 19, 2016), emu roo (Dec 27, 2025), EnginePaul (Jul 5, 2018), Grumpyoldman (Jan 14, 2016), Home-PC (Jun 26, 2022), jjr2001 (Nov 27, 2016), Jon (Jan 10, 2016), kbalch (Jan 10, 2016), Okapi (Jul 6, 2018), Paul Jones (Jan 10, 2016), PJs (Jan 12, 2016), SA MAKER (Mar 29, 2019), Scotsman Hosie (May 9, 2019), Stevohdee (Jul 4, 2018), Tonyg (Mar 29, 2019), Vyacheslav.Nevolya (Jan 17, 2016)
