Results 1 to 6 of 6
Thread: Torsional beam mini lathe stand
  1. #4
    Stockholm, Sweden...
    DIYSwede's Tools
    Guess these pics better show than those previously posted:
    Yup - I'm amidst a complete teardown and upcoming headstock alignment, as I found it's out 0,147 mm in 113 mm run.
    (I.e. close to 6 thou in less than 4.5"!)
    Not just "cutting a taper" - a veritable cone manufacturing machine!
    "-As I was just checking the bed alignment on the RHS mount, I realized that..."
    Headstock bolts were loose, apart of a bad initial fitting and the spindle bearings aren't coaxial with the headstock centre line.
    The only thing I didn't check after my initial "delivery teardown & overhaul" 2 years ago.
    Didn't want to disturb the motor at the time, and as all the other milled & ground surfaces was tight, flat, nice and perpendicular...
    I just assumed... No more of that - Measuring is Knowing.
    Wow - really. The fun never ends. At least nothing is broken. Being a cheap guy - my time for this is free! -Whoopee!
    Last edited by DIYSwede; Jun 8, 2019 at 10:48 AM. Reason: correction, clarification
