Results 1 to 10 of 24
Thread: Twin 30" Belt Sander/Grinder
  1. #5
    Supporting Member mr95gst's Avatar
    Apr 2014
    Murfreesboro, TN, USA
    mr95gst's Tools
    That is fantastic and inspiring! Did you have to mill the back of your castings flat or lots of sanding? Your finished pieces look clean and uniform. I always struggle with making a uniform appearance with my finished castings. I usually end up machining every surface because I haven't found a good way to blend a cast finish into a machined surface without it looking odd. Whatever you did looks good.
  2. The Following User Says Thank You to mr95gst For This Useful Post:
    Carlos B (Mar 13, 2017)
