Results 1 to 10 of 10
Thread: Universal Insert Lathe Tool bit Holder....Get any angle on that tool bit.
    jjr2001's Tools
    I saw this on line while watching a video and it looked so good I had to make one.
    The demo that I was watching was using an Aloris cartridge insert tool bit.
    This unit could be set to various angles in multiples of 15 degrees.
    I wanted mine to be any angle! So I left out the cogs and just made a smooth cartridge.
    I am using TCMT carbide bits but HSS bits are available and I am waiting for mine to arrive.
    I cut a steel rod in the lathe. Faced it, turned a shoulder, made a chamfer, and turned a cylinder without
    changing the tool bit. On my mini lathe I made cuts of .020 infeed or .040 material removal per pass and
    the operation went smooth without the insert moving and without chatter. What more do I need?
    TCMT insert use an M2.5x.45 tapered screw..(get mine from LMS)
    The cartridge is retained with an 8-32 allen cap screw.
    So here a couple of pics and my simple drawing of this versatile tool bit.
    Make one, you will love it.
    Cheers, JR
ID:	37428   Click image for larger version.
ID:	37429   Click image for larger version.
ID:	37430   Click image for larger version.
ID:	37431   Click image for larger version.
ID:	37433   Click image for larger version.
ID:	37434   Click image for larger version.
    Attached Files Attached Files
    Back to the shop.
  2. The Following 18 Users Say Thank You to jjr2001 For This Useful Post:
    baja (Dec 7, 2020), bruce.desertrat (Dec 2, 2020), Canyonman44 (Dec 2, 2020), Christophe Mineau (Dec 3, 2020), clavius (Dec 2, 2020), desbromilow (Dec 29, 2020), Dimsa (Dec 2, 2020), DIYSwede (Dec 3, 2020), GKK (Dec 4, 2020), Home-PC (Dec 2, 2020), Jon (Dec 2, 2020), kngtek (Dec 3, 2020), nova_robotics (Dec 2, 2020), olderdan (Dec 3, 2020), phred (Dec 2, 2020), Sleykin (Mar 9, 2021), sossol (Dec 2, 2020), VegeKev (Dec 2, 2020)
