Thread: Using a long series drill
    Berkshire UK
    thehomeengineer's Tools
    Exclamation Using a long series drill
    Hi All
    Again this my not be of interest to everyone.
    I am still working on the cylinder block for my the 3”scale Foden Steam Wagon and thought I’d share how I drilled the regulator shaft holes with a 3/32” long series drill.
    The holes needed to enter one side of the cylinder block and pass through a cast cavity and out the other side (3.5” total depth) The two holes need to be in line so the shaft can move freely to regulate the steam valve. Due to diameter and depth I was unable to centre drill the second hole. I could have however drilled from each side of the casting, but any slight error would have resulted in misalignment.
    So the method I used is as follows:
    The casting was first marked out and clamped to the mill table and angle plate. The spindle aligned over the required position for the hole. Centre drilled and drilled with a standard 3/32 diameter drill. A scrap piece of steel 1/2” square was then de-burred and clamped into the machined area were the regulator will ride up and down. This piece of steel was then spot drilled from the first 3/32 hole. The orientation of the block marked and cutoff to create a guide bush. The guide bush was then clamped as close as possible to the next hole to guide the long series drill. Without the guide bush the drill would have wondered off.
    The hole came out spot on to the marked out hole position on the opposite side of the casting.
    The photos will hopefully clarify my explanation.
    Using a long series drill-79a823d6-af24-473b-b619-608b4703b35f.jpegDrilling hole and spotting through into square guide bush.
    Using a long series drill-965eeeda-c3d2-42da-aeb5-fad777d503a8.jpegCutting guide bush.
    Using a long series drill-f7204af7-17e7-4ca9-b454-31dc3ae2a5f6.jpegGuide bush in position ready to be clamped in place.
    Using a long series drill-69b8c3be-d6d2-4fa1-aa04-79790ffb0775.jpegClamped guide bush in position.
    Using a long series drill-eb371072-51e3-4ea8-81a8-a056bc11cc5e.jpeg3/32 drill supported in guide bush and hole drilled with long series drill.
    Using a long series drill-b3ee8a2b-1ca6-49de-9079-29593c6d75ac.jpegOpposite side, hole on marked out lines.
    Hope this will assist anyone using long series drills.
    Thank you for viewing
    The Home Engineer
    Attached Thumbnails Attached Thumbnails Using a long series drill-77c56190-630b-49b3-89e6-565f393ad9f0.jpeg
  2. The Following 12 Users Say Thank You to thehomeengineer For This Useful Post:
    Christophe Mineau (Feb 20, 2023), Frank S (Feb 12, 2023), Inner (Feb 19, 2023), mwmkravchenko (Feb 17, 2023), nova_robotics (Feb 19, 2023), oddjob_jobs (Mar 13, 2023), olderdan (Feb 17, 2023), Philip Davies (Feb 16, 2023), Scotty1 (Feb 12, 2023), Toolmaker51 (Mar 10, 2023), trevor_60_r (Feb 12, 2023), Wildwilly (Feb 19, 2023)
    Congratulations thehomeengineer - your accurate long drilling method is the Tool Tip of the Month for February 2023!
    This is a clever and useful technique that will apply to a variety of projects.
    Some more nice tool tips from February:
    Gasket Tying by Frank S
    Deep Slot Machining by thehomeengineer
    Part Picture Scaling by Occasional machinist
    Gear Cutting by Alans Home Workshop
    Using Specimen Tubes in the Shop by mklotz
    Drill Sharpening by Alans Home Workshop
    thehomeengineer - we've added your Tool Tip to our All Tool Tips of the Month winners post. And, you'll now notice the tool tip award in the awards showcase in your postbit, visible beneath your username:
    And, you'll be receiving a $100 online gift card, in your choice of Amazon, PayPal, or bitcoin. Please PM me your current email address and gift card choice and I'll get it sent over right away.
    Congrats again
    Dec 2015
    Reading, Berks, UK
    Philip Davies's Tools
    Great job.
