Thread: Vintage work crew photos
  1. #2461
    neilbourjaily's Tools
    OSHA!? What about California's cancer warnings? I think residents f the Golden State are warned not to breathe.
  2. #2462
    Quote Originally Posted by neilbourjaily View Post
    It has been proven that ONLY those who breathe can get cancer. That MUST be the cause!!!!
  3. #2463
    Hoosiersmoker's Tools
    CALOSHA also discovered that saliva causes death... but only if swallowed in small quantities over a long period of time...
    "The man who views the world at 50 the same as he did at 20 has wasted 30 years of his life."
    - Muhammad Ali
  4. #2464
    Not a teeny bit. Just try shopping a solid object without a Proposition 65 Warning. Even stainless steel. https://www.google.com/search?client...d&q=CA+Prop+65 .They all cook in clay pots?
    Nearly as persuasive as the more genuine water shortage; but find a brown golf course, even in the desert....not yet!
    No matter how irritating liberals and woke-ees are, they provide endless entertainment for sensible folks.
  5. #2465
    Quote Originally Posted by NeiljohnUK View Post
    I agree it's the low pressure section of a multi-stage (H.P.(I.P.?)L.P.) steam turbine of it era, in the 1960's/70's 500 MW sets I worked on that's smaller than the I.P. section.....snipped......would lead to differential cooling and a bent turbine shaft, we even had a 'ride the tool post' lathe big enough to machine the LP sections.
    What a terrific technical description. As clear you worked that yesterday!
    That "barring over" required of very accurate rotating assemblies carried on elsewhere too......Though ball bearings had been around some time, they were barely able to sustain speeds and loads of early jet turbine engines. They were kept turning slowly to avoid flat spots on bearing assemblies. The airflow requirements of intake/ exhaust made remaining space limited; way different then found in something like a motor case, real end bearings and maintaining thrust clearances.
    Last edited by Toolmaker51; Jan 17, 2022 at 12:35 PM. Reason: picked up good quote
  6. #2466
    Not a teeny bit. Just try shopping a solid object without a Proposition 65 Warning. Even stainless steel. ...
    Many Proposition 65 warning signs required in various establishments are printed on heavy plastic.
    I wish I had the money to fund a chemistry lab to prove that the signs, when heated by the sun, give off gases that "are known to the state of California to cause cancer".
    Then I could take the state to court and make them put Prop 65 warnings on the Prop 65 signs.
  7. The Following 2 Users Say Thank You to mklotz For This Useful Post:
    neilbourjaily (Jan 17, 2022), Toolmaker51 (Jan 17, 2022)
  8. #2467
    Proof is near already made; off-gassing is going on all the time. One example is film that collects inside auto windshields; vaporized petroleum products. Can't recall one plastic not petro based. Proof is near already made; off-gassing is going on all the time. One example is film that collects inside auto windshields; vaporized petroleum products. Can't recall one plastic not petro based.
    That film by the way is difficult to remove; glass cleaner is not efficient or effective. Pro's use 70%+ clinical alcohol and micro-fiber towels, not paper or cotton.
  9. #2468
    Any asphalt off-gasses. It's called VOC. Volatile Organic Compounds is. OMG! What about the vinyl in mu old pickup?
  10. #2469
    Wheel shaping workers. Wheel and Axle Division. McKees Rocks, PA. April, 1962.
    Fullsize image: https://diqn32j8nouaz.cloudfront.net...g_fullsize.jpg
  11. The Following User Says Thank You to Jon For This Useful Post:
    nova_robotics (Jan 24, 2022)
  12. #2470
    Workers building a Douglas A-20 Havoc. Long Beach, California. 1942.
    Fullsize image: https://diqn32j8nouaz.cloudfront.net...w_fullsize.jpg
  13. The Following 7 Users Say Thank You to Jon For This Useful Post:
    cmarlow (Jan 30, 2022), emu roo (Mar 30, 2026), Floradawg (Feb 1, 2022), marksbug (Jan 31, 2022), nova_robotics (Feb 5, 2022), Rangi (Feb 4, 2022), Toolmaker51 (Jan 30, 2022)
There are currently 107 users browsing this thread. (0 members and 107 guests)
