Results 1 to 9 of 9
Thread: Water fill adapter for lawn tractor tires
    We use our little lawn tractors more for moving things around than we do mowing, their biggest failing point is the lack of weight over the drive tires. I decided that since mine had flats on both rear tires that I would install heavy puncture resistant tubes in them then maybe this summer I will replace the tires with Wider more aggressive tread ATV tires but in the meantime why not water fill the ones on it to add some much-needed weight where it will do the most good.
    For this I needed an adapter to connect the garden hose to the valve stem. Milton makes a female air plug that fits the quick connects which had the .305-32 thread which fits the stem. somehow I happened to have one but don't ask me where it came from. I took a Hose bib that had a 1/8" NPT outlet for an evaporative cooler line to which I threaded in a 1/8 inch brass hex nipple then bushed up to 1/4NPT and installed an air hose quick connector. I mounted the tires without putting any air in the tubes. Instead of airing them up I watered them up to seat the beads and bring them to the hardness I wanted. The adapter allows for insertion of the valve stem through it without the need to unscrew it first but to do that I had to modify a cheap core removal tool by grinding away part of the handle.
    There is right at 9 gallons of water in each tire this adds a significant amount of weight right where it is needed most
  2. The Following 10 Users Say Thank You to Frank S For This Useful Post:
    baja (Apr 25, 2022), bruce.desertrat (Apr 20, 2022), davesrepair (May 14, 2024), DIYer (Apr 21, 2022), emu roo (May 1, 2025), Jon (Apr 21, 2022), mwmkravchenko (Apr 24, 2022), NortonDommi (Apr 22, 2022), nova_robotics (Apr 20, 2022), Sleykin (May 1, 2022)
