Thread: wire cutting guillotine
    Berkshire UK
    thehomeengineer's Tools
    Hi All
    Following on from the chains I made for my 1" traction engine Re-think on wire bender for making chain links I thought I would share the wire cutting guillotine I made to support the manufacture of the chain links.
    There are commercially made wire cutting guillotines mainly used in the jewellery trade that can be purchased from the normal websites, but reading the reviews I decided to make one that would be a little more industrial for my purpose.
    The criteria for the tool was to be simple to use and a stop that could be accurately set. The cutting blades to be made interchangeable so if worn or damaged can be replaced. Commercially made cutters don't offer this so once worn the whole tool will need to be replaced.
    The stop on my guillotine is set by using slip gauges.
ID:	33541 Click image for larger version.
    The stock material is a combination of mild steel and gauge plate. Stock metric screws and spring also used in build.
    Brass slug used to prevent stop shaft being damaged from screw, see link for more details
    How to prevent grub screws from damaging outer diameters
    Stop and shafts
ID:	33549 Click image for larger version.
    Main body and base. The base allows for the tool to be held in bench vice.
ID:	33558 Click image for larger version.
    Guillotine handle and handle retainer.
ID:	33556 Click image for larger version.
    Gauge plate blades hardened and tempered. Several size wire diameters can be cut.
ID:	33553 Click image for larger version.
    Removable cutting blades in place in main body and handle
ID:	33564 Click image for larger version.
ID:	33565 Click image for larger version.
    Spring return of handle
    Setting the piviot pin and locking in place with grub screw
ID:	33562 Click image for larger version.
ID:	33567 Click image for larger version.
    Stop and wire being fed into guillotine.
    Completed tool
    Wire cut to length.
    I hope this is of interest and thank you for viewing.
    The Home Engineer
  2. The Following 6 Users Say Thank You to thehomeengineer For This Useful Post:
    bobs409 (Feb 15, 2020), byates (Feb 18, 2020), Jon (Feb 17, 2020), Philip Davies (Feb 18, 2020), Scotsman Hosie (Feb 17, 2020), suther51 (Feb 17, 2020)
