I did away with the tacho and voltmeter up top, simplified it by just mounting the speedo on the top tree, I'll put some idiot lights in the headlight bucket.. The voltmeter is now below the right hand side panel. I'll either connect it to the battery via a toggle switch or connect it to the brake light wiring.
I designed and taped up a couple of harnesses a while back, decided to go with two: One for ignition, plus the neutral cable, the other for lighting. A much simplified system for fault finding. Four wires in one, six in the other, although I think I'll delete the neutral cable, don't see any need for that or the tacho. It still needs a little tidying up, a bit raggedy at the moment.
Scraping the barrel for fabrication and machining work now, only have to finish off the wiring and fit brake lines, chain and sprockets and mufflers, nearing the end, what'll I do when I finish. This build has been very enjoyable, learnt lots of new cuss words.
