Page 20 of 33 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 LastLast
Results 191 to 200 of 322
Thread: 1974 XS/TX650 rebuild
  1. #191
    What about the master cylinder?
    I have not seen a slave cylinder like the one that you have. 12/14 mm bore does seem small if it was direct acting but it looks like it retains the original Yamaha actuating scroll. I was expecting something like this
    1974 XS/TX650 rebuild-clutchslave.jpg
    That is why in a previous message I expressed an interest in how you would mount it.
  2. #192
    Oct 2015
    th62's Tools
    I doubt I'll be using this slave cylinder, it's just something to experiment with.
  3. #193
    Oct 2015
    th62's Tools
    I've designed and put together a couple of much simplified harness' one for lights, the other for ignition, minus stuff I don't require, neutral light and so on. But still the spaghetti bucket lived up to it's name. I dislike untidy with a vengeance so made a bracket that sits inside the spaghetti bucket to try and keep things neat and make it easier to find and connect the wires.
    Two grommets sit in the middle for routing earth wires through to earth connections and a couple of linked, Delrin, insulated terminal bridges sit either side of them for power connections. Mostly connected up, but still have to connect the headlight cables and speedo light cables, not sure about adding idiot lights, more procrastination needed there me thinks! The cables emanating from the switchgear are very, very light gauge, not sure if they'll handle the current, even though all lights are LEDs, so I may have to either solder in heavier gauge cables or change the switchgear.
    Attached Thumbnails Attached Thumbnails 1974 XS/TX650 rebuild-win_20220319_14_32_46_pro.jpg   1974 XS/TX650 rebuild-win_20220319_14_40_29_pro.jpg   1974 XS/TX650 rebuild-win_20220319_16_24_00_pro.jpg
  4. The Following 2 Users Say Thank You to th62 For This Useful Post:
    asterix (Mar 19, 2022), tonyfoale (Mar 19, 2022)
  5. #194
  6. #195
    Oct 2015
    th62's Tools
    Finished off the front wiring and spaghetti bucket. Still looks a little untidy, but neater than most I think. I even mounted the lens on a couple of wire safety straps to stop it pulling on the harness. I had, to buy these double female bullet connectors from China, couldn't find anyone in OZ who stocks them. Trying to find sub 6mm eye terminals was a job, same with 3mm blade terminals, they stock female blades but not males. And they complain that everyone is turning to online shopping - no bloody wonder.
    Got to attack the back end now, mount the indicators and plug them and the tail light into the lighting harness.
    Attached Thumbnails Attached Thumbnails 1974 XS/TX650 rebuild-win_20220321_15_49_00_pro.jpg   1974 XS/TX650 rebuild-win_20220321_15_57_49_pro.jpg   1974 XS/TX650 rebuild-win_20220321_16_44_22_scan.jpg
  7. The Following User Says Thank You to th62 For This Useful Post:
    asterix (Mar 21, 2022)
  8. #196
    Oct 2015
    th62's Tools
    The indicators I bought don't have a long enough threaded section to go through the guard bracket, so I made these extension brackets to mount the indicators on. The V shaped cut out at the rear of the brackets fits around the frame tab protrusion, thus stopping the brackets from moving.
    Attached Thumbnails Attached Thumbnails 1974 XS/TX650 rebuild-win_20220323_11_50_31_pro.jpg   1974 XS/TX650 rebuild-win_20220323_11_44_22_pro.jpg   1974 XS/TX650 rebuild-win_20220323_11_43_51_scan.jpg
  9. #197
    Oct 2015
    th62's Tools
    Nup, binned them. Looking at the picture I noticed the line on the top the aluminium bracket doesn't follow the line on the top of the frame tab. So I made a new pair. Not a lot I could do with the bottom line as the tab angle is different to the guard angle, so I followed the tab angle down to the bottom of the guard then followed the arch of the guard. I might have to thin it down a bit though, looks a bit too big???
    Attached Thumbnails Attached Thumbnails 1974 XS/TX650 rebuild-win_20220323_17_50_06_pro.jpg
  10. The Following 2 Users Say Thank You to th62 For This Useful Post:
    asterix (Mar 23, 2022), tonyfoale (Mar 23, 2022)
  11. #198
    Aug 2020
    The thinner bottom part of the first bracket look better. The pointed end of the upper part looks akward. Perhaps a rounded end ?
  12. #199
    Rikk's Avatar
    Nov 2018
    Rikk's Tools
    What if you added a radius to the bottom edge of the bracket similar to the radius of the fender lip. Not that anyone would notice it unless they looked directly at it from the side, but it keeps the lines smooth and consistent.
  13. #200
    Oct 2015
    th62's Tools
    Nope, if I did that then the lower fork would be horrendously thick. That's why I followed the line on the bottom of the tab down to the guard then followed the line of the guard.
  14. The Following User Says Thank You to th62 For This Useful Post:
    Rikk (Mar 29, 2022)
There are currently 5 users browsing this thread. (0 members and 5 guests)
