Results 1 to 5 of 5
Thread: Attaching an occasional use encoder to a lathe spindle.
    Cool Attaching an occasional use encoder to a lathe spindle.
    There are times when I need to fit a rotary encoder to my lathe for precise measuring. Accurately measuring the profile of camshafts is one example use. I originally used a 3 post mount, but as you can see after the drive belt conversion (described in a previous post on this forum) and now a large 50 tooth timing wheel that is not possible. The solution, which was inspired by a friend, was to support the encoder with the spindle plug and then it is only necessary to prevent rotation. The torque is absolutely minimal so I used a piece of 2 mm plastic sheet which is rigid in the rotation direction but flexible in the axial direction, thus preventing any misalignment from loading the bearings in the encoder.
    It only takes 30 seconds to mount it when needed.
Name:	Cam measuring 07.JPG
ID:	44158 Click image for larger version.
Name:	Rotary encoder 01.JPG
ID:	44157 Click for full size images
    This is my original encoder mount. A piece of rubber tube connected the pip on the spindle plug to the encoder shaft.
ID:	44159 Click image for larger version.
    Here is the new plug made in Delrin. The fit is so good that the O-rings are not necessary but seem like a good idea. All machining including the hole for the encoder spindle was done in a single setting to ensure concentricity. The encoder spindle is a push fit in the plug and no other fixation was needed.
ID:	44161 Click image for larger version.
    Everything in place. The plastic sheet is wide and hence rigid in the direction to locate the rotary motion of the encoder, but thin and hence flexible in the axial direction which allows for misalignment tolerances.
    BTW. The eagle eyed may have noticed that there is oil in the sight glass on the old photo but there is no oil in today's photos. A while back I changed from oil to grease for bearing lubrication. The bearings run much cooler now, due to the lack of oil churning.
  2. The Following 6 Users Say Thank You to tonyfoale For This Useful Post:
    emu roo (Nov 16, 2022), Home-PC (Nov 16, 2022), Jon (Nov 16, 2022), mwmkravchenko (Nov 16, 2022), nova_robotics (Nov 16, 2022), rebuilder1954 (Nov 17, 2022)
