Results 1 to 5 of 5
Thread: Attaching an occasional use encoder to a lathe spindle.
  1. #2
    Marion, Iowa
    metric_taper's Tools
    Tony, I have a 1976 Jet 1024 lathe. It was made in Taiwan. The head stock is similar casting as well the sight glass is the same. I found when I pulled the spindle many years back, that there was only a single hole going from the oil reservoir to the bearing (the hole level with the normal oil level). The sight glass is a front plug for this reservoir. This hole was straight back to the roller bearing. So the sight glass could show oil at the lower line level, but the bearing could be dry. So I modified both the front and rear bearing reservoirs, by drilling a 1/8" hole from the rear bottom of that reservoir to the bottom of where the bearing cup is. So now when I run the lathe, the oil is pumped out of the reservoir and circulates with the bearing (which was unintended). When running the sight glass shows the level has dropped to nothing on the sight glass. Your lathe probably did not have the design or manufacturing error, so the bearings were working as an oil pump.
    I know you reworked your whole spindle arrangement on this lathe, and did away with the back gear. I think you filled the head stock with concrete to increase mass and reduce vibrations.
    In your last two photos of this post, you do have a photo-optic shaft encoder. Is this added one more resolution?
  2. The Following User Says Thank You to metric_taper For This Useful Post:
    emu roo (Jul 17, 2025)
