Results 1 to 10 of 15
Thread: Balanced Cheater Bar for Ratchet
    Supporting Member IAMSatisfied's Avatar
    Apr 2017
    The desolate ranch country of Northeastern corner of New Mexico, USA
    IAMSatisfied's Tools
    This tool is pretty straightforward... I needed a way to apply torque to a ratchet using both hands to apply the torque rather than one hand supporting the head of the ratchet and only the free hand applying the force. It works well for my use.
    This is made from a piece of 1/2" steel pipe and a piece of flat bar and fits the handles of several different makes of 3/8" ratchets.
    I realize one can buy a T-handle socket wrench, but I live in the sticks and "running down the street to the hardware store" wasn't an option. This utilizes common scrap, is inexpensive and works well.
    The transmission is strapped down to limit movement, a requirement.
  2. The Following 31 Users Say Thank You to IAMSatisfied For This Useful Post:
    Andyt (Dec 23, 2021), baja (Aug 15, 2024), barnaby72 (Aug 14, 2024), bob_3000 (Oct 10, 2023), BrianW (Dec 24, 2021), BuffaloJohn (Dec 23, 2021), cognitdiss (Dec 23, 2021), cohay1 (Aug 14, 2024), DIYer (Dec 28, 2021), emu roo (Oct 4, 2025), EnginePaul (Dec 27, 2021), flyfr8rs (Aug 14, 2024), Frank S (Dec 23, 2021), Gadgeteer (Oct 10, 2023), hemmjo (Dec 23, 2021), highpointpat (Dec 27, 2021), JoeVanGeaux (Dec 23, 2021), johncg (Dec 23, 2021), Jon (Dec 22, 2021), mdhatter3 (Dec 22, 2021), mr mikey (Aug 14, 2024), nova_robotics (Dec 22, 2021), rgsparber (Dec 26, 2021), robertblacksmith (Oct 11, 2023), schuylergrace (Dec 22, 2021), sossol (Dec 22, 2021), Tooler2 (Aug 14, 2024), Toolmaker51 (Dec 23, 2021), Tule (Dec 27, 2021), verticalmurph (Dec 28, 2021), wombat50 (Dec 26, 2021)
    Oct 2012
    Lafayette, Indiana
    sossol's Tools
    I've needed something like this more times than I can count. This is far too elegant for me to think up, so I'll just copy yours.
    Neil
  4. The Following User Says Thank You to sossol For This Useful Post:
    Apr 2016
    Buffalo, NY
    Neat idea. Simple and easy to make and useful. Thanks
  6. The Following User Says Thank You to mdhatter3 For This Useful Post:
    Mar 2013
    Perth Western Australia
    Peter Sanders's Tools
    Hi Yes, a neat and simple idea as mdhatter3 said. But you are not lessening the force required, you are just splitting the same amount of effort between two hands (arms). Making the cheater bar "longer" by extending ALONG the handle end, reduces the effort required by ONE hand. Obviously with the need to hold the ratchet in place with the other hand. Using the shortest possible socket extension minimises the effort required to hold the ratchet in place, and minimises the "distorted" leverage that tries to pull the socket away from the bolt/nut.
    I think the longer bar is better. Perhaps, when in use) you could place the tube part of the tool the opposite way around and have the welded bar point away from the ratchet head. You'll get the extra leverage that way. This tool offers the best of both worlds, well done.
  8. The Following 2 Users Say Thank You to Peter Sanders For This Useful Post:
    emu roo (Oct 4, 2025), verticalmurph (Dec 28, 2021)
    Supporting Member schuylergrace's Avatar
    Sep 2020
    Mesa, Arizona
    Can you flip it around and use it as a cheater bar, too? This thing is perfect in its simplicity!
  10. The Following 3 Users Say Thank You to schuylergrace For This Useful Post:
    emu roo (Oct 4, 2025), IAMSatisfied (Dec 23, 2021), verticalmurph (Dec 28, 2021)
    Very nice, the is on my todo list now!!!
  12. The Following User Says Thank You to hemmjo For This Useful Post:
    Turns a ratchet into a ratcheting T bar, I like it.
  14. The Following User Says Thank You to Frank S For This Useful Post:
    katy's Avatar
    Jul 2019
    Red Deer Alberta
    katy's Tools
    Neat idea, thanks for posting.
  16. The Following User Says Thank You to katy For This Useful Post:
  17. #9
    Congratulations IAMSatisfied - your Balanced Cheater Bar is the Homemade Tool of the Week!
    Another huge week around here, but the simple and clever solution wins it this week.
    Bandsaw Feed System by thehomeengineer
    Air System Water Trap by Frank S
    Lantern Chuck by neilg4dbn
    Metal Bender by Kwandotechnic
    Blast Door Latch by thehomeengineer
    Belt Grinder Anti-Static Strap by mr_modify1
    Circle Cutting Tool Jig by orioncons36
    Stuck Powerlet Extraction Method by mklotz
    LED Limiting Resistor Calculation by mklotz
    ER32 Chuck by carl blum
    Spindex Accuracy Modifications by mr_modify1
    Spiling Stick by Philip Davies
    Tap Organizer by mr_modify1
    Pipe Fitting Removal Method by Frank S
    Guitar Neck Jig by sossol
    Trailer Wheel Bolt Circle Adjustment by Frank S
    Electronic Edge Finder by mr_modify1
    End Mill Sharpening Fixture by mr_modify1
    Knife Sharpening Jig by fox craft
    Plastic Box Reinforcement by mr_modify1
    Drill Sanding Attachment by Mr.DK DIY
    Swivel Fitting and Black Pipe Seal by Frank S
    Bolt Down Milling Plate by editor@glue-it.com
    IAMSatisfied - we'll add your tool entry to our All Homemade Tool of the Week winners post. And, you'll now notice the wrench-on-pedestal award in the awards showcase in your postbit, visible beneath your username:
    And, you'll be receiving a $25 online gift card, in your choice of Amazon (US-only), PayPal, or bitcoin. Please PM me your current email address and award choice and I'll get it sent over right away.
    Nice work!
  18. The Following User Says Thank You to Jon For This Useful Post:
  19. #10
    Supporting Member wombat50's Avatar
    Jan 2021
    Canberra, Australia
    Great idea! Elegant in its simplicity. As is often the case the simplest solution is usually the best.
  20. The Following 2 Users Say Thank You to wombat50 For This Useful Post:
