Results 1 to 8 of 8
Thread: Doc's Rasp for the arthritic
    Doc
    Doc is offline
    Supporting Member Doc's Avatar
    May 2013
    Doc's Tools
    Lightbulb Doc's Rasp for the arthritic
    Hi everybody
    Made this rasp from an old broken band saw blade.
    Several cut to size (whatever they are - about 200mm) and a total of 9mm diameter means it's a very useful tool for making slots in wood (I'm a wooden toymaker) that are, well, 9mm wide
    Having arthritic hands and a wood lathe means I just had to make some handles for it. A bit over the top, but I enjoy having a play.
    An oversize hole allows the blade(s) to be firmly pushed in and epoxied in, not that they really need the epoxy.
    Thanks for having a look.
    Regards
    Doc
  2. The Following 3 Users Say Thank You to Doc For This Useful Post:
    Christophe Mineau (Feb 10, 2015), kbalch (Feb 10, 2015), Scotsman Hosie (Dec 18, 2019)
    Jul 2014
    France, Brittany !
    Christophe Mineau's Tools
    Nice, I already saw the trick for the several blades, but the second handle is a great addition !
    How many layers of blade did you put together ?
    One must never through away anything , especially old bandsaw blades. (or hacksaw blades)
    Cheers !
    Christophe
    Facebook : La Belle Note
  4. The Following User Says Thank You to Christophe Mineau For This Useful Post:
    Doc (Feb 10, 2015)
    kbalch's Avatar
    Jun 2012
    Clermont, FL
    Thanks Doc! I've added your Wood Rasp to our Woodworking category, as well as to your builder page: Doc's Homemade Tools. Your receipt:
  6. The Following User Says Thank You to kbalch For This Useful Post:
    Doc (Feb 10, 2015)
    Doc
    Doc is offline
    May 2013
    Doc's Tools
    Thanks Christophe. I just ducked out and counted -11 layers all up and a quick re-measure shows it's 6mm wide not 9mm.
    No wonder I found it useful - 6mm is a typical size for some of the timber I use.
    Must admit, the end handle was more an attempt to see if I could turn a sphere(ish) shape free hand
    Regards
    Doc
    Feb 2013
    South of Brazil.
    Hotz's Tools
    Very nice ...
    Sorry my mistakes in english.
  9. The Following User Says Thank You to Hotz For This Useful Post:
    Doc (Feb 10, 2015)
  10. #6
    Jul 2014
    San DIEGO, California
    Captainleeward's Tools
    O Yah music to my ears..... good idea Doc.
  11. The Following User Says Thank You to Captainleeward For This Useful Post:
    Doc (Feb 10, 2015)
  12. #7
    Jul 2014
    France, Brittany !
    Doc,
    did you arrange the teeth direction all the same way or did you alternate ?
    Cheers !
    Christophe
  13. The Following User Says Thank You to Christophe Mineau For This Useful Post:
    Doc (Feb 11, 2015)
  14. #8
    Doc
    Doc is offline
    May 2013
    Doc's Tools
    I alternated them. No reason, just remembered seeing a bought one that looked like that
    On reflection, I should try another one with them all facing the same way like a Surform type rasp.
    Regards
    Doc
