Results 1 to 7 of 7
Thread: Flywheel and ring gear installation measurement
    hemmjo's Tools
    I need to fit a new ring gear on a flywheel. I want to know
    the sizes of the ring gear and the flywheel to get an idea how
    hot to get the ring to slip it into the flywheel.
    I have my dad’s Starrett 0-12” inside micrometer set to measure the ID
    of the gear. Those measurements vary between 11.960 and 11.967.
    Twelve measurements at 6 positions averaged to 11.9615”.
Name:	01 Measure ring.jpg
    I have nothing to accurately measure the OD of the12” flywheel.
    After some thought, the lathe could used as a caliper. A brass rod
    was freshly faced in the chuck and a dial indicator mounted in the
    tailstock chuck. For my purposes the actual size is not as critical
    as the difference in size.
Name:	02 Lathe Caliper .jpg
    DTI Tail Stock Chuck Adapter
    By removing the compound slide and stacking shims on the
    cross slide, the flywheel can rest firmly at proper height to
    contact the rod and the indicator. The cross slide easily moves
    the flywheel to center with the indicator.
Name:	03 shims.JPG
    With the flywheel in place, the tailstock quill was advanced and
    locked with the indicator reading 0.200”. Then back the cross
    slide out, rotate the flywheel 60˚ and slide it back into place.
Name:	04 side view.jpg
    The clutch bolt holes provided reference for rotating the wheel.
    Working all the way around, 6 measurements were within 0.001”
    off some unknown value.
Name:	05 measure flywheel.jpg
    Removed the flywheel and replaced with the inside micrometer.
    Then adjust the micrometer so the DTI reads 0.200”.
    The flywheel measures 12.025”
    12.025 - 11.960 = 0.065”
    According to an online calculator,
    https://goodcalculators.com/thermal-...on-calculator/
    the steel ring gear will expand about 0.0657”I.D. at ∆T of 750˚f.
    The service manual says to heat the gear to 400˚f, and to not
    exceed 450˚f. This makes sense to me as the gear is heat treated.
    This is WAY too hot to avoid ruining the temper in this gear.
    Finding these measurements made me to do more research. I have discovered several sources with a gear, same fitment description, with the advertised size of 11.994.
    12.025 - 11.994 = 0.031”
    ∆T of 425˚ is 0.037 should expand the gear to 12.031”.
    It should slip right on.
    Will let you know when the new gear arrives.
  2. The Following 4 Users Say Thank You to hemmjo For This Useful Post:
    ductape (Jan 16, 2026), Jon (Feb 5, 2026), metric_taper (Feb 7, 2026), nova_robotics (Jan 16, 2026)
