I have the "c" clamp style vice grips that would do great for this, as long as the punch out is 1" or biger, but a small c clamp would be eazy to use too for the small ones. I just happen to be doing all the electrickel in my 3rd shop Im just about done building. the effing square D POS breaker box has punchouts.... but the effing things are not centered withen each other. and the largest size is what I need... but... for some stupid reason they did not make that one round. they made the smaller ones the back edge of the biuger one... yup 2 different radii so the fitting wont go through.I had to take it all appart and put in milling ,achine and use a carbide hole saw to cut the holes.....you cant fix stupid. some know it all effing moron engineer. to top that off all the reciptical boxes are made for 1/2 emt fittings... I wanted to use 1" conduit throught, but there is none to be found due to covid 19.so I went with 3/4 and had to machine every box for 2-3 fittings. oh well Ive always got to be different and I like things the way I want them so Im used to it.
Marksbug,
What would you do differently if there is a next time? I'm sure you learned a lot from this experience.
Rick
(Engineer)
