Results 1 to 10 of 13
Thread: Lathe Cutting Tool for O-ring Grooves (and trepanning)
Hybrid View
    May 2014
    Del Mar, California
    Paul Jones's Tools
    I machined an O-ring groove located a little too close to a part’s inner corner for using my old lathe O-ring cutting tool. I tried running the lathe in reverse so I could approach the O-ring groove from the more narrow side of my O-ring cutting tool but still not enough room for the tool.
    I have been wanting a more universal O-ring cutting tool so I ground a new O-ring cutting tool made from an old blank of Rex AAA HSS. The tool cutting face width is 0.095” and 0.5” long (to the shoulder) and ground at an offset of 30 degrees from the center line to provide better access. In addition to using the cutting tool for making O-ring grooves, it is also does a great job as a trepanning tool. I used it recently to remove a 3.5” diameter center section from a plate of T-304 stainless steel. The Rex AAA HSS had no trouble trepanning the stainless steel. I included some photos of the tool at work.
    Attached Thumbnails Attached Thumbnails Lathe Cutting Tool for O-ring Grooves (and trepanning)-custom-o-ring-cutting-tool-limited-access.jpg   Lathe Cutting Tool for O-ring Grooves (and trepanning)-custom-o-ring-cutting-tool-limited-access-side-view.jpg   Lathe Cutting Tool for O-ring Grooves (and trepanning)-small-o-ring-cutting-tool-limited-access.jpg   Lathe Cutting Tool for O-ring Grooves (and trepanning)-attemping-o-ring-groove-machining-using-reverse-rotation.jpg   Lathe Cutting Tool for O-ring Grooves (and trepanning)-removing-center-section-custom-lathe-trepanning-tool.jpg
    Lathe Cutting Tool for O-ring Grooves (and trepanning)-center-section-removed-custom-lathe-trepanning-o-ring-groove-tool.jpg
  2. The Following 17 Users Say Thank You to Paul Jones For This Useful Post:
    billster (Apr 15, 2018), C-Bag (Jan 15, 2016), emu roo (Oct 8, 2025), jjr2001 (Sep 1, 2016), Jon (Jan 10, 2016), JRock (Apr 15, 2018), kbalch (Jan 11, 2016), LMMasterMariner (Nov 22, 2017), mwmkravchenko (Jun 1, 2023), NortonDommi (Nov 16, 2017), nova_robotics (May 12, 2022), olderdan (Nov 17, 2017), PJs (Jan 12, 2016), Sleykin (Nov 18, 2017), sossol (Dec 27, 2023), Tonyg (Dec 27, 2019), Vyacheslav.Nevolya (Nov 17, 2017)
    kbalch's Avatar
    Jun 2012
    Clermont, FL
    OK, that's not what came to mind when I read "trepanning"!
    Ken
  4. The Following 2 Users Say Thank You to kbalch For This Useful Post:
    emu roo (Oct 8, 2025), Paul Jones (Jan 11, 2016)
    Thanks Paul! We've added your Groove and Trepanning Tool to our Lathes category, as well as to your builder page: Paul Jones' Homemade Tools. Your receipt:
    PJs
    PJs is offline
    Sep 2014
    Northern CA
    PJs's Tools
    Thanks Paul! Your grind work is beautiful and the radii...Wow! Never heard of the tool material but took a look at Crucible's site. Lots of tungsten (18%) and seems to have a balanced all around toughness, hardness and abrasion resistance at 64-66HRC. Did you have to grind it with diamond or special stone and are they good for particular metals? Can't see much of a rake (clearance angle) to it? Thanks for the tip on these!
    Looks like your 4 jaw was about maxed out on that plate but the finish looked great from what I could see!! Made a custom trepan/o-ring cutter out of a P1 cuttoff blade a while back to use on acrylic. The thin undersection of the P1 worked great for cooling from the hot plastic...slow to work but did fine with it. Thanks for sharing your great work! ~PJ
    Mark Twain
  8. The Following User Says Thank You to PJs For This Useful Post:
    May 2014
    Del Mar, California
    Paul Jones's Tools
    Thanks PJs. The Rex AAA HSS tool bit is one very tough cookie but can be ground with conventional aluminum oxide wheels on a pedestal grinder using a rough 36/46 grit to take away most of the material. The final grind finish was with 120 grit silicon carbide wheels.
    I have another pedestal grinder (toolmaker style) that has 100 and 220 grit diamond wheels but didn't want to waste the diamonds on this tool but may use the 220 grit to product an ultra smooth finish if needed next time. I ground a 10 degree side angle clearances on the sides of tool and added an undercut to the front tip by removing 0.22" for more clearance for the small radius O-ring grooves. In the trepanning work for the T-304 stainless steel plate, I had to run the lathe at 70 RPM and still ran into a lot of chatter and squeak (you know it is bad when even the dogs leave the garage because of the noise - I had my -30dB ear muffs on ). Thanks for the questions, Paul
  10. The Following 2 Users Say Thank You to Paul Jones For This Useful Post:
    emu roo (Oct 8, 2025), PJs (Jan 13, 2016)
  11. #6
    PJs
    PJs is offline
    Sep 2014
    Northern CA
    PJs's Tools
    I hear ya clear over here!
    I get the side clearances for O-Rings, especially. Thanks Much! ~PJ
    Mark Twain
  12. The Following User Says Thank You to PJs For This Useful Post:
  13. #7
    Dec 2013
    Florida
    rossbotics's Tools
    Good work Paul
    I been needing one of those myself, wouldn't use it allot, but would be nice to have when the moment arrives, when I was coming up In the shop all we had was old rex95 tool bits,
    Looks like it did a nice job on that tough old stainless,
    Great post
    Doug
    Comments are always welcome
    Doug
  14. The Following 2 Users Say Thank You to rossbotics For This Useful Post:
    emu roo (Oct 8, 2025), Paul Jones (Jan 19, 2016)
  15. #8
    Dec 2016
    Ralphxyz's Tools
    Trepanning
    Trepanning, also known as trepanation, trephination, trephining or making a burr hole is a surgical intervention in which a hole is drilled or scraped into the human skull, exposing the dura mater to ... Wikipedia
    Just had to google trepanning
    Ralph
  16. The Following User Says Thank You to Ralphxyz For This Useful Post:
  17. #9
    Trepanning
    A better definition for "trepan" looks like this...
    a tool for cutting out circular blanks or for making grooves around a fixed centre.
    the operation of cutting a hole with such a tool; the hole so produced
    In surgery, the hole in the skull is not "drilled" as one would use a drill in a drill press to make a hole. Rather a device similar to a hole saw is used to remove a circular piece of skull. The resulting hole gives access to the brain. When the procedure is done the circular bit of skull can be sown back into place and will heal over to close the hole quickly.
    In surgery the intent is to save and reuse the material from the hole. In metalworking we do the same thing when we use a hole saw and then repurpose the slug removed from the hole.
    In many metalworking applications the intention is not to make a complete through hole but rather to make a groove or depressed area in the workpiece. Many flywheels have a depressed center to lighten them without seriously diminishing their moment of inertia. The process of turning this depression is referred to as trepanning, the gerund form of "trepan".
  18. The Following User Says Thank You to mklotz For This Useful Post:
  19. #10
    Dec 2016
    Ralphxyz's Tools
    Thanks Marv, I knew there had to be a metalworking definition.
    Ralph
  20. The Following User Says Thank You to Ralphxyz For This Useful Post:
