Home made "Marvin" attachment horizontal to vertical mill conversion.
1" spindle with MT2 taper.
Thanks glens5! We've added your Horizontal Mill Vertical Conversion to our Milling category,
as well as to your builder page: glens5's Homemade Tools. Your receipt:
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/homemade-horizontal-mill-vertical-conversion"> <img src="/uploads/233704/homemade-horizontal-mill-vertical-conversion.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/homemade-horizontal-mill-vertical-conversion">Horizontal Mill Vertical Conversion</a> <span> by <a href="https://www.homemadetools.net/builder/glens5">glens5</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/mill'>mill</a>, <a href='https://www.homemadetools.net/tag/conversion'>conversion</a>, <a href='https://www.homemadetools.net/tag/modification'>modification</a> </div> </div> </div> </div>
Pretty slick. How well does it work?
Elegant. Simple. Good job of doing ones best to battle Murphy.
Very nice. I'm thinking that it is super smooth in use?
Countless little horizontal mills went to scrap because potential buyers couldn't visualize this.
Driving from the machine spindle infinitely better than placing that weight atop the fabricated spindle housing. And, still have ready use of the horizontal spindle. You say the bore is #2 Morse Taper; appears those are drawbar [not drift] holders?
Takes a few minutes to set up and align but other than that it seems to work just fine.
I haven't checked for run out yet but if there is any I'm sure it'll be from the Banggood collets and holder.
The over arm support is 2 1/2" for the for the horizontal spindle support so I turned the vertical attachment from 3" cold rolled steel.
The bearings are tapered roller bearings, L44643. I turned an extra fine thread on the top of the spindle for adjusting the end play and run out to zero with a special machined castle nut with a round collar that projects through the top seal.
I wasn't able to turn the bearing cup seats with the two sections welded together and was concerned about the weld pulling but with the wall of the housing close to 1" thick there didn't appear to be any distortion. Peening the short alternate welds may have helped too.
Interference fits for the spindle bearings as well as the bearings in the idler pulleys.
MT2 taper with a draw bar. MT3 would have been preferred but would have been too large.
Given my name, I have a vested interest in this question...
Why is it called a "Marvin" attachment ?
Certainly not an original idea on my part but it looked like a good idea for converting to vertical.
Nice solid conversion in keeping with the original machine, well done.
QUOTE=mklotz;160157]Given my name, I have a vested interest in this question...
Why is it called a "Marvin" attachment ?[/QUOTE]
Because calling it a "Frederic" attachment just sounds dumb. Though I remain very attached to my horizontals...
Really nice build! Thanks for sharing!
Personally, I've been down on my luck on BG MT2 & MT3 ER32 collet holders (4 of them, all in all).
2 years between placed orders hoping the harsh buyer feedback would've shaped up their quality issues. Guess not...
Link: https://www.youtube.com/results?sear...Collet+sets%22
The Collet holders: +/- 5 hundreds of a mm in runout (sic!) and non-coaxial to boot in all 4 cases...
Worse than the worn-down 3-jaw in the 50 years old lathe at work...
My only REAL LEMONS in a 70-ish item order history - too bad that would happen to "precision pieces"...
No biggie for me to regrind the ER32 tapers down to below +/- 2 thousands of a mm, tho -
about half of the ER32 collets in the (M & Imp) sets were in as bad a shape as the holders, too:
both non-coaxial and non-concentric when tried in the new-ground holder.
Finish was excellent, throughout - no rough edges, finely ground and clean
(others have reported bad cuts, rough edges and shavings within).
Even being cheap-to-the bone and given my 20-20 hindsight, I shouldn't have ordered them in the first place.
Guess I now have to shim their compressible saw cuts up, fit them in holder and regrind 'til "good enuff"?
-Yeah, right! Sub-6 mm collets just a piece of cake to regrind! "Happy machining!"
As per their original state - the bad ones are perfectly useless for my intended purpose.
-Why even pay for runout and non-coaxiality, when you could get that for free in a dirty, old 3-jaw? :D
Just my 2 cents & YMMV
Johan
PS: Perhaps the small collets could be honed? Another upcoming project/ waste of time?
Congratulations glens5 - your Horizontal Mill Vertical Conversion is the Homemade Tool of the Week!
Huge week around here, with multiple tools that could've won on a less busy week, but this is a very nice build.
Chicken House Pest Control by Frank S
Rotary Table Pallet by jjr2001
Welding Magnet Cleaner by Mr.DK DIY
Drill Bit Sharpening Jig by machining 4 all
Belt Grinder by winkys workshop
Mini Dumper by warsztatOdZera
Copper Coating Method by Kovanca Polock
Electromagnetic Drill Stand by bouboulas
Threading Die Holder by machining 4 all
Outfeed Stand by Christofix
Small Bore Chamfering Tool by metric_taper
Bench Grinder by h7eh7e
Set Square by Philip Davies
Tailstock Spanner by desbromilow
Indicator Holder by craig9
Hydraulic Press by Mr.DK DIY
Threading Tool by mariost
Turntable by HandmadeCreativeChannel
DTI Holder by celsoari
Tap Handle by theeddies
Angle Grinder Cutting Fixture by fawabros
Router Guide by Mad Halfling Inventor
Pocket Hole Jig by Mazay
Wood Drying Press by liberal
glens5 - we've added your tool entry to our All Homemade Tool of the Week winners post. And, you'll now notice the wrench-on-pedestal award in the awards showcase in your postbit, visible beneath your username:
https://www.homemadetools.net/forum/...OfTheWeek4.pnghttps://www.homemadetools.net/forum/...eWeekIcon4.png
You've also been granted free lifetime Supporting Member status, which means you can now access all of the tool plans and tool ebooks in our Supporters Forum (thanks to mklotz for that idea). And you'll now notice the Supporters award in the awards showcase in your postbit:
https://www.homemadetools.net/forum/.../Supporter.pnghttps://www.homemadetools.net/forum/...porterIcon.png
You'll be receiving a $25 online gift card, in your choice of Amazon, PayPal, or bitcoin. Please PM me your current email address and award choice and I'll get it sent over right away.
Nice work! :thumbsup:
Well that is interesting. It is amazing how many of these old manufactures have gone away.
Consider bedding them in low-temp alloy. Most are bismuth based, the low temp won't alter heat-treating or anneal what-so-ever. Plug ID with a stub of properly sized aluminum rod, so drilling and boring will be easy. Chuck the holder and dial in. These are educated guesses, certainly easier and more precise than 6 or 8 tiny shims...
I checked the run-out on the Banggood collets. Some are as much as +/- .010 and the mt2 taper holder +/- .002 so a poor buy at any price.
The spindle run-out is negligible but I had turned the inside mt2 taper at the same time as the rest of the spindle on the lathe so I'd be surprised if there was any.
@ TM51: -Thanks for that (hitherto unconsidered by me) tip!
-Haven't even got any Wood's metal to start with, but I guess I'll have to score some now.
@glens5 : Bummer that BG hasn't shaped up their QC for these items during the years, and also:
their complaints department "didn't seem to fire on all cylinders", or was merely using a stalling strategy.
And then suddenly my "forthright and factual" review on their page got lost somehow...:)
Finally - after a tedious and tragi-comical e-mail chain I finally got my refund (less pp and local tax, tho).
Looking forward to perhaps eventually waste another fine 10 hours of grinding these "freebie" collet sets.
-See, it doesn't take much to make a cheap, masochistic hobby machinist happy!
I don't spend a lot of money gambling, when tools are purchased, and frequently buy used. Hence, my assembly of tooling rivals most any shop I've worked in, including some quite large.
I might call them Danggood.
From what's been heard here of Banggood, can only depend on that being a noise, after handful dropped on a concrete floor...
BangGood or Aliblahblah don't cross my radar often. My pop-up windows are a high percentage of women's fashion, or trolling for that squinky-eyed presidential candidate. I'm clearly not being profiled accurately.
But just moments ago, here is one for BangGood themselves! Selling Hawaiian styled vacation shirts.
Nothing says engineering/ quality control of tooling like casual wear celebrating tropical birds and foliage.
Who knew?
I've found those Banggood Blue Nano endmills to be pretty long lasting and they're cheap (if you can hold metric diameters).
Nice job. I did similar in my youth had forgotten all about it!
a place I workd back in the mid 90's tried to give me a horizontal and a shaper. I had no way of getting them home as well as a 1 car garage... I wish i had got them. 3 years lator I built a 24x34' shop/garage 6 steps out my bedroom door. oh well I got a millport 9x42 around 2008 and a enco bench top mill around 2001. one free one for $500 pluss $100 to move the big one. I wanted CNC but you take what you can afford. like the new enco 9x20 lathe that was broken in shipping I got for about $200 that took me a day to fix then another day to get the enco out of it...all the gear shafts have a keyway sleve(built in key way on a sleve so they dont have to sleve the shaft I reckon) all of those were made offset.... what a effing wining noise all those gears made. I fixed them and a few other crap things and you cant hear it run now. not bad for a light duty 9x20. it's almost as usefull as my 7x14 mini lathe. but no where as stiff.I need to mount the 9x20 on a peice of granite.off coarse Ill have to tear it all appart and put the bed on my mill upside down and sqwuare up the bottom mounts to the ways first
I too have a lot of bangod stuff.chucks,end mills,carbides tool holders, calipers etc, but now days it's cheeper and faster on ebay.
i AGREE. a little shopping around witch i usualy do and many are cheeper then the shipping makes it higher. same with car parts. like rock auto, all the rong parts your car will never need with eqach thing shiped from a different whorehouse for added shipping cost and when you get it its' yours... no way to contact any body at rock auto. just a automated return prosess that might take it back after you pay shipping both ways.. like a $8 part that cost you $10 to ship both ways.... after rong parts in every order and no people to talk with....nomore rockauto for me. it's a massive scam org.
