Results 1 to 10 of 11
Thread: Nut Spliter for M6-M8-M10-M12nuts
    Supporting Member kess's Avatar
    Dec 2015
    Thessaloniki Greece
    kess's Tools
    Sometimes nuts are too much seized on screw or head is so much damaged or too much stuck from rust and they cannot be unscrewed with conventional tools.
    With this simple tool, just put the nut you want to loosen into the hole of the Nut Splitter Tool and screw the bolt until the nut breaks.
    If needing to be save the bolt in some cases, then do not over tighten to prevent damage to the threads under the nut.
    Nut Splitter also is known as Nut Cutter or Nut Cracker.
    I made it using a M24 nut
    a piece 45mm of rod ø19mm
    a piece 25mm which I cut from the tail of an HSS ø10mm drill bit
    one bolt MF12x1.25x50mm
    two nuts MF12x1.25mm
    and a ball bearing ø8mm.
Name:	first frame_NB.jpg
ID:	29506 Click image for larger version.
ID:	29485 Click image for larger version.
ID:	29487 Click image for larger version.
ID:	29488 Click image for larger version.
ID:	29490 Click image for larger version.
ID:	29491 Click image for larger version.
ID:	29493 Click image for larger version.
ID:	29494 Click image for larger version.
ID:	29496 Click image for larger version.
ID:	29497 Click image for larger version.
ID:	29499 Click image for larger version.
ID:	29500 Click image for larger version.
ID:	29502 Click image for larger version.
ID:	29503 Click image for larger version.
ID:	29505 Click image for larger version.
ID:	29507 Click image for larger version.
ID:	29509 Click image for larger version.
ID:	29510 Click image for larger version.
ID:	29512 Click image for larger version.
ID:	29513 Click image for larger version.
ID:	29515 Click image for larger version.
ID:	29516 Click image for larger version.
ID:	29518 Click image for larger version.
ID:	29519 Click image for larger version.
ID:	29521 Click image for larger version.
ID:	29522 Click image for larger version.
  2. The Following 18 Users Say Thank You to kess For This Useful Post:
    12L14 (Jul 31, 2019), Altair (Apr 29, 2019), Andyt (Jun 25, 2021), baja (May 1, 2019), DIYer (Apr 30, 2019), emu roo (Sep 29, 2022), Jon (May 2, 2019), kboy0076 (Oct 23, 2023), nova_robotics (Sep 28, 2022), Paul Jones (May 13, 2019), PowerMk (May 1, 2019), Scotsman Hosie (Apr 30, 2019), Seedtick (Apr 30, 2019), that_other_guy (May 14, 2019), Tonyg (May 1, 2019), Toolmaker51 (Apr 30, 2019), Tule (May 1, 2019), volodar (Apr 30, 2019)
