Results 1 to 7 of 7
Thread: Offset tool bit holder for the lathe
    jjr2001's Tools
    https://sherline.com/wp-content/uplo...08/tip_093.pdf
    Sherline Machinist Tip 93. Compound slide tool holder for threading from the front side.
    The Sherline compound slide is designed to be used from the rear with an inverted tool bit.
    This works and has its's advantages. However when threading on the lathe I like my tool bit
    in the front and cutting edge up.
    This little block allows the tool bit to be "right side up" and at the front of the lathe.
    I used the pictures in the tip #93 and my own measurements of my compound to make the part.
    Next time I set up for threading it will be the tool to use.
    Cheers, JR
ID:	25894   Click image for larger version.
ID:	25895   Click image for larger version.
ID:	25896   Click image for larger version.
ID:	25897   Click image for larger version.
ID:	25899   Click image for larger version.
ID:	25900   Click image for larger version.
ID:	25901   Click image for larger version.
  2. The Following 15 Users Say Thank You to jjr2001 For This Useful Post:
    celticprince (Mar 12, 2022), emu roo (Jun 28, 2024), G.Paul (Oct 2, 2018), high-side (Jan 14, 2019), HobieDave (Mar 18, 2020), jeanalvitre (Oct 8, 2018), Jon (Oct 2, 2018), LMMasterMariner (Oct 2, 2018), old_toolmaker (Oct 3, 2018), Paul Jones (Oct 17, 2018), PJs (Oct 2, 2018), rossbotics (Oct 2, 2018), Seedtick (Oct 2, 2018), Shanty (Oct 5, 2018), Tonyg (Jan 10, 2019)
