Results 1 to 9 of 9
Thread: Power feed for mini lathe and mini mill
  1. #6
    May 2016
    Don42's Tools
    Your 20 RPM gear motor is rated at 0.31 kg-cm torque, at 0.6 amps. This 220 RPM 12-volt motor,
    https://tinyurl.com/2p8r37x7
    is rated for 0.875 kgf-cm of torque at 1.4 amps, or 2.8X the torque of your 20 RPM motor, so it could handle your entire range of speeds and loads. If driven by a little over 1 volt it would turn at about 20 RPM. The motors with greater gear reduction might be a bit "stiffer" (more constant speed) with varying loads, but a motor controller with speed feedback would be very stiff.
  2. The Following 2 Users Say Thank You to Don42 For This Useful Post:
    dgbreggin (Jun 11, 2022), emu roo (Aug 15, 2025)
