Results 1 to 10 of 12
Thread: Precision Vise. Milling Vise. DIY 100% Homemade!
  1. #2
    Supporting Member machining 4 all's Avatar
    May 2020
    machining 4 all's Tools
    Below is a brief description of the tools and materials needed for its execution:
    - Drill 5.0 mm
    - Drill 6.0 mm
    - Drill 7.0 mm
    - Drill 8.0 mm
    - Drill 10.0 mm
    - Drill 14.0 mm
    - End mill 10.0 mm
    - Countersink diameter 19.0 mm
    - Male M6
    - Male M8
    - Plate 32.0 mm x 102.0 mm x 182.0 mm
    - Plate 32.0 mm x 62.0 mm x 102.0 mm
    - Plate 32.0 mm x 32.0 mm x 102.0 mm
    - Plate 18.0 mm x 27.0 mm x 37.0 mm
    - Round bar diameter 21.0 mm x 9.0 mm
    - Allen screw M6 x 30.0 mm
    - Allen screw M8 x 50.0 mm
    Approximate cost:
    - Plates and round bar (scrap): U$8.00
    - Screws: U$0.50
    - Labor: it's part of the fun!
    Approximate manufacturing time:
    - 3 days (with several interruptions)
    Full project available below!
    Attached Files Attached Files
  2. The Following User Says Thank You to machining 4 all For This Useful Post:
    DIYSwede (Aug 10, 2020)
