Altair (Jan 18, 2015), baja (Apr 6, 2019), Big-Pete (Mar 18, 2021), billster (Oct 12, 2018), Canobi (Mar 18, 2021), Christophe Mineau (Jan 19, 2015), darkoford (Oct 11, 2018), EnginePaul (Oct 11, 2018), greyhoundollie (Oct 14, 2018), high-side (Jan 16, 2019), IAMSatisfied (Mar 23, 2018), j.bickley (Oct 12, 2017), kbalch (Jan 15, 2015), Metallurg33 (Aug 1, 2022), mwmkravchenko (Oct 12, 2018), ncollar (May 21, 2016), NickP (Oct 12, 2017), nova_robotics (Mar 17, 2021), olderdan (Oct 16, 2017), Paul Jones (Jan 15, 2015), quickcut (Aug 4, 2022), Ralphxyz (Mar 17, 2021), rlm98253 (Mar 22, 2018), Scotsman Hosie (Apr 6, 2019), thevillageinn (Oct 22, 2017), Tuomas (Mar 23, 2018), VegeKev (Mar 22, 2018), winmac (Dec 28, 2022)
Thanks Captainleeward! I've added your Fan Belt Welding Jig to our Welding category, as well as to your builder page: Captainleeward's Homemade Tools. Your receipt:
greyhoundollie (Oct 14, 2018), Ralphxyz (Feb 24, 2023)
Captain,
How fast do you have to work between withdrawing the soldering gun tip and closing the gap to form the weld? Also, is there any surface trimming needed for the welded joint after it hardens? This looks like an interesting jig for making my welded urethane belts for my small Unimat lathe and milling head setup.
Thanks for showing this, Paul
Mc Master Carr also sells it. https://www.mcmaster.com/urethane-belts/
Hi Paul, It is important to move the hot ends back together as quick as possible, With this machine the ends are mated perfect.
Hello ED, urethane belts, they come any length you need and size on e-bay just type in urethane belts.
Thanks to all for your interest....:O)
EnginePaul (Oct 11, 2018), Paul Jones (Jan 19, 2015), Scotsman Hosie (Apr 6, 2019), Tuomas (Mar 23, 2018)
Great idea Captain , as I also never thought of using urethane as a pulley belt.
When heating ends , would it work easier if you added a thin flat blade to the tip of the soldering iron to act as a heating surface and then press the two cut ends together or use the thin blade as a cutting blade which also provided enough heat to allow fusion of the two cut surfaces..?
