Results 1 to 10 of 11
Thread: Unimat Lathe Cabinet for Storing Tooling and Supporting the Lathe and Milling Machine
    May 2014
    Del Mar, California
    Paul Jones's Tools
    A couple years ago I built a small cabinet for my old Unimat SL lathe and added a separate vertical column for the milling/drilling head. The cabinet has only one drawer with four separate compartments, and one of the compartments has two layers. The cabinet sides, drawer, and drawer front are made from ¾” red oak and finished with clear satin polyurethane. The top and bottom are made from ¾” Melamine particleboard laminated with a thermally fused resin coating to provide a durable and oil-proof hard surface. I made the knurled knobs from ½” aluminum rod.
    The cabinet sits on four rubber feet whereby the combined weight of the lathe and tooling stored in the drawer provides enough weight to keep the lathe from moving on the workbench. The cabinet top has threaded brass inserts for holding the milling column base to a 1”x3”x12” aluminum bar using cap head screws. The lathe sits on two 1”x1”x6” aluminum riser blocks that are held in place with flathead machine screws inserted from underside of the top sheet of melamine and secured with washers and brass nuts. The two sides and back of the cabinet contain 10-32 threaded inserts I made for cap screws to hold optional Lexan splash shields when fly cutting with the milling head.
    More information about the Unimat lathe modifications can be seen at http://www.homemadetools.net/forum/m...00-lathe-10111 .
    Attached Thumbnails Attached Thumbnails Unimat Lathe Cabinet for Storing Tooling and Supporting the Lathe and Milling Machine-unimat-improvements-cabinet.jpg
  2. The Following 4 Users Say Thank You to Paul Jones For This Useful Post:
    backyard_cnc (Feb 13, 2016), Christophe Mineau (Nov 17, 2014), kbalch (Nov 17, 2014), natie123 (Apr 9, 2024)
    That's a neat storage solution Paul.
    Al
  4. The Following User Says Thank You to Altair For This Useful Post:
    Paul Jones (Nov 16, 2014)
    Jul 2014
    France, Brittany !
    Christophe Mineau's Tools
    Really Nice !
    I definitely love when projects merge wooden things and metal
    I like the knurled buttons.
    Is the nice chest on you bench done by you also ?
    Christophe
    Cheers !
    Christophe
    Facebook : La Belle Note
  6. The Following User Says Thank You to Christophe Mineau For This Useful Post:
    Paul Jones (Nov 17, 2014)
    Like the guys here, I have varied interests, so any storage solution that keeps the varied stuff from mingling is of interest to me. Nice job on this one.
    Feb 2013
    South of Brazil.
    Hotz's Tools
    Very cool.
    Sorry my mistakes in english.
  10. The Following User Says Thank You to Hotz For This Useful Post:
  11. #6
    kbalch's Avatar
    Jun 2012
    Clermont, FL
    Thanks Patrick! I've added your Lathe Cabinet to our Metalworking and Woodworking, and Storage and Organization categories, as well as to your builder page: Patrick's Homemade Tools. Your receipt:
  12. #7
    May 2014
    Del Mar, California
    Paul Jones's Tools
    Christophe,
    Yes, the cabinet in the background was also made by me when I was a teenager and almost fifty years ago. This one was made from scrap plywood. Back then I cut the wood parts with one of those circular saw adapters that fitted onto a corded 1/4" power drill. Seems pretty crude compared to what I now have in my shop but it worked and I learned a lot from the experience. By the way, I wanted to line the cabinet drawers in green felt but it was just after Christmas when I built the cabinet and the red felt was on sale, so I bought it instead. Here is a photo of one of the drawers to the old cabinet. I also included another photo of my first tool cabinet I built when I was fourteen and again made it from scrap plywood that the lumberyard owner gave to me for free. I still use both of the old cabinets along with a couple of the Kennedy machinist tool chests.
    Thanks for asking, Paul
  13. The Following User Says Thank You to Paul Jones For This Useful Post:
    Christophe Mineau (Nov 18, 2014)
  14. #8
    Supporting Member crazypj's Avatar
    Nov 2014
    Central Florida
    crazypj's Tools
    What a brilliant idea, wish I had thought of it.
    I'm going to have to make one
  15. The Following User Says Thank You to crazypj For This Useful Post:
    Paul Jones (Nov 29, 2014)
  16. #9
    Mar 2014
    Beaumont, TX
    Paul Alciatore's Tools
    Saw this on a Homemade Tools e-mail today and it is really neat.
    I also have a Unimat DB-200, the original CI model which I am presently restoring with a new paint job. I have a full steel bench dedicated to it. But I may copy some of your other ideas that I see in the photos. I long planned to add a caliper and DI for DRO capability so I am studying your photos carefully. I also would like to add a permanent vertical column but I think I would use a metal base plate, probably aluminum, to tie it to the Unimat. I don't see why you have to use an actual Unimat column as any 25mm diameter rod would work.
  17. #10
    For the benefit of future readers...
    The only improvement I might suggest is a piece of 1/8" steel plate under the Unimat. That would allow one to use all sorts of magnetic bases to hold measuring tools, lubrication feeds, lights, microscopes etc.. DAMHIKT. I have a Unimat too and had to add the steel plate as an afterthought.
