Results 1 to 10 of 322
Thread: 1974 XS/TX650 rebuild
    Oct 2015
    th62's Tools
    Slack day today, just made up a few static timing lights of different design. First one uses a 9 volt battery, so had to solder a resistor in the line to cut the voltage down. Second one works off the bike battery, so also had to use a resistor. Third one uses a 3 volt button battery, so, so resistor required. Why so many? I was bored!
ID:	39507   Click image for larger version.
ID:	39508   Click image for larger version.
ID:	39509   Click image for larger version.
ID:	39510   Click image for larger version.
  2. The Following User Says Thank You to th62 For This Useful Post:
    greenie (May 15, 2021)
